AirBag Fault B0002:64 Help Please
Renegademaster
Unread post by Renegademaster »
Hi I am getting an airbag fault B0002:64 Permanent Level 2 driver airbag line--Line present but not configured. comes on after I switch off and on again.
also only been present since using token on diagbox to reinstate active cruise after a crash.
Any help much appreciated
x 6956
Re: AirBag Fault B0002:64 Help Please
You can't reset these after a crash - it needs a new airbag control unit.
Renegademaster
I have already cleared the crash from the unit with a CG100X but this seems to be a configuration error with the thing being connected to diagbox and configuring the thing maybe to left hand drive spec,
Renegademaster
could someone possibly get the correct configuration for the airbag unit so I can do a manual config with Diagbox
Renegademaster
Unit is a Veoneer 9849207580 for a Mokka E Ultimate
x 6956
I don't have anything for a Mokka - and many later vehicles don't have configuration info for the Airbag unit as they're supplied pre-configured now (as they're supposed to be replaced after crash lockout).
Renegademaster
Sorted now,
I used https://carprogonline.com/ to erase the data on the module instead of doing it on the CG100x
Thanks for your Time Marc
x 6956
