Original Diagbox with token login issue (explained)
Djandree
x 38
Unread post by Djandree »
Hello
Recently I spent 2 weeks trying to sort it out Original Diagbox issue with login. Cut the long story short (all started on 16th June 2024)
There is a link to original Diagbox from PSA
https://public.servicebox-parts.com/dia ... ndent).exe
Please skip update to version v9.149 (last working and tested by me with access to Serav and Ediag). I did try to update up to ver. v192 but this update is not working with Serav and Ediag servers. (lengthy emails and even phone call from PSA IT support ended up with no more answer from them after they deleted my norton360 antivirus and left me in the bushes) Have to work out all by myself. Even received a script showing what should work to have a connection with PSA servers but option 3 didn't work at all - had an access anyway.
First you have to activate diagbox to work with token (using X_ _ _ _ from your PSA account) then fill out forms address etc, then change language and language in emergency for English and restart Diagbox for changes to take effect. Then login into desired brand (AN _ _ _ + password for https://public.servicebox-parts.com), and at the end click F12 to do a connection test
Now you are ready to do some scanning etc.
I hope this tutorial will help
[The extension zip has been deactivated and can no longer be displayed.]
x 6945
Re: Original Diagbox with token login issue (explained)
You don't need an account with PSA for diagnostics - only if you require diagrams or configuration. As many people with DB 7.** have 'modified' software this will likely deactivate their versions of Diagbox so connection to PSA servers is not recommended - unless you are using their unmodified software from the PSA site.
Djandree
x 38
Yes I know. But there is plenty of post regarding modified Diagbox, but there is nothing when you need an access to diagrams or telecoding and you are forced to update Bsi for example.
I forgot to add a docx from PSA with requirements to running Diagbox software
Djandree
x 38
Ha I can't add docx. Anyway if someone will need it. Please let me know
x 1939
Djandree wrote: 07 Jul 2024, 11:48Ha I can't add docx.
Convert it to a PDF, that will upload no problem.
Djandree
x 38
mmm got this when I am trying to upload a file
ERROR
Invalid file extension: DOC_DB_HW_SW_Requirements__DiagBox_EN_V4.0.pdf
x 1939
Djandree wrote: 07 Jul 2024, 12:53 mmm got this when I am trying to upload a file
ERROR
Sorry, I was wrong. PDFs aren't allowed either.
Wrap the file inside a ZIP. Providing it is not too large, that will upload.
x 6945
It's freely available from PSA's website to those with accounts who want to purchase tokens or download the official Diagbox, so no need to post it here to be honest... and as it is constantly being updated, the information may will not be relevant in the near future. Best for people to get the latest info direct from the PSA website at the time. :wink:
Djandree
x 38
Heh. Thanks for idea. I am new to this forum thing... Full support got win11 so It will take some time...
Djandree
x 38
GiveMeABreak wrote: 07 Jul 2024, 14:02 It's freely available from PSA's website to those with accounts who want to purchase tokens or download the official Diagbox, so no need to post it here to be honest... and as it is constantly being updated, the information may will not be relevant in the near future. Best for people to get the latest info direct from the PSA website at the time. :wink:
Got some user guide and installation guide on my account both out of date.... DiagBox User Guide Supplement – July 2010, Installation guide for IO DiagBox – 2017_10. So there is a new one then
x 6945
We'd prefer you don't upload this sort of material to the Forum, as it's really just taking up unnecessary storage and as I already mentioned, documents of this nature are constantly being updated, so serve little purpose as anyone that requires the official Diagbox software can already access these documents direct from the portal.
Faroza
Unread post by Faroza »
Hello, I spent about 3 weeks installing diagbox, but I always encountered the same result, after the diagnosis is over, it goes to the main menu and nothing is clicked here. When I do the connection test, the ediag and serav part remain unanswered, and the others have a check tick. First, I tried my own personal pc to install, antivirus and firewall did not allow it, I got an incomplete installation error, then I installed it by deleting the firewall without antivirus on another computer where I installed completely cleanly. After that, I saw that you finished the global test without any problems, but after it's over, nothing is clicked, I activated it with a token.
When I click on the user login panel and log in, it becomes green, thinking that I made a mistake in the password, my username IS AN... and I changed my password, it didn't happen again, I made my token code the same with the site login code (because I'm not sure which password you want) again the same result is clicked on anything. By the way, after activating the token, it seems on my service box screen that I still have not started to use it, what I may have skipped, I am grateful for any help, thanks.
I apologise for the typo.
Bogdan652
Unread post by Bogdan652 »
Hi all,
I try to download original diagbox from the link above, but is not working :(
Can you help me with a functional link.
Thank you in advance
Bogdan652
I managed to install the official version 9.179. It connects to all services, after scanning the car I try to see the errors and it does nothing. I have purchased token/chip and I expect that after scanning the car when I want to see the errors and eventually update the modules it will ask me if I am using the purchased token/chip, but it won't even let me see the errors.
How/when does it ask me to use the token/ token purchased.
I appreciate any help.
x 6945
What are you actually trying to do? You don't need a token for a diagnostic.
Why do you think there are updates for any modules? You should leave these alone unless you want more problems if you don't have a reason for it.
