Hi to All
Thank you from the start
I have a 2023 Citroën C5 Aircross. Recently, I noticed that the battery was not performing well, so I decided to replace it. After installing the new battery and connecting everything, the car won't start. I even connected the power jumper, still won't start
When I open the door, a message briefly appears saying "Economy mode activated," and then everything goes dead. The remote fob does not lock or unlock the car, the windows won't open, and the display on the infotainment system remains off. The only lights that stay on for a few minutes are the 'P' (Park) position indicator and the handbrake light, but they eventually turn off as well.
I've read about potential solutions online, but my car is completely unresponsive, so I can't try any of them. The windows won't open, the remote fob is useless, and there's no power to anything in the car.
If anyone has any suggestions or advice on what I can do to resolve this issue, I would be extremely grateful.
Citroen C5 Aircross in Economy mode will not start
unitedbirlik
- x 5688
Re: Citroen C5 Aircross in Economy mode will not start
Some Citroens and specifically C5s have a somewhat elaborate procedure for disconnecting the battery and reconncting it. If you have not followed this procedure it may have caused problems with the car's electronics, primarily the BSI.
This is the required method.
Try following it and hopefully normality will be restored.
- x 1955
Exactly what battery have you fitted?
- x 1061
Surely this vehicle is still under manufacturers warranty? If there was an issue with the battery should really have gone to dealer.
- x 6950
I agree, get it back to the dealer under warranty if you can start it, otherwise book it in and get your home start breakdown to tow it at a time when the dealership can look at it and give you a hire car.
- x 1061
Make sure you refit the original battery back in if taking it to the dealer incase they point the finger of blame at you.
I heard that the handbook says "If the car has problems after battery changing a period of immobility is needed i.e. leave the car standing for around 8 hours then try again."
Don't ask!
Don't ask!
- x 6950
That may relate to the resetting of the climate control on some C4 Picasso models after a battery replacement for the system to recalibrate. I wrote about that somewhere a while back IIRC.
GiveMeABreak wrote: 29 Jun 2024, 10:19 That may relate to the resetting of the climate control on some C4 Picasso models after a battery replacement for the system to recalibrate. I wrote about that somewhere a while back IIRC.
Comment came from my neighbour's grandson who is a mechanic who has all the tools including expensive Snap-On diagnostics kit but seems to do most of his work with a 2lb lump hammer.
