Hi all,
For the past few months every time I've started the 3008 when the weather outside is hot
The air conditioning blower fan immediately started working at full power without the possibility of
lowering its power and without the possibility of turning on the air conditioning (buttons at the air conditioning screen do nothing but the touch screen is working fine).
In addition to that, the central switch panel did not respond (apart from the hazard warning and central locking).
Starting last week the problem got worse and it appears every time the vehicle is started.
It is important to note that the system does not return to normal during driving.
I tried disconnecting the battery for a few minutes and the problem was not solved.
Does anyone have any idea what the problem could be?
Air conditioning blower fan working at full power and central switch panel not responding
Oren_OP
- x 6948
Re: Air conditioning blower fan working at full power and central switch panel not responding
Likely to be the blower motor control module that has failed.
Oren_OP
Thank you for the reply,
Is it possible that a faulty blower motor control module is responsible also to the problem with the central switch panel (it doesn't respond)?
- x 6948
Which switch panel? and which specific buttons were not working? A picture may help along with the VIN.
Oren_OP
The central switch panel -see pic, all buttons not working (apart from the hazard warning and central locking)
- x 6948
In that case no, there's likely something else going on. Check the rear connections, but it really needs a diagnostic to determine if it's the control panel or something else.
Oren_OP
Ok, I'll try to check what's going on, thanks a lot
