DS5 AdBlue Issues P20EE00 P20F600 P2A0000 P16EA00
skragamuffin
Re: DS5 AdBlue Issues P20EE00 P20F600 P2A0000 P16EA00
hi hoping for a response on an old thread lol anyone know where the adblue injector is on the exhaust as in having simular issues with my ds5 white smoke and ammonia smell
thanks all
thanks all
- x 1489
skragamuffin
2.0 derv 150 bhp engine code is DYZK if any help
- x 6945
That's not an engine code, best to provide the VIN for these fault codes to save asking later, but if the 150 engine, it'll be the first box section after the manifold.
skragamuffin
sorry it was first digits of engine number and thank you very much for the answer also do you think a forced dpf regeneration may help as i have an icarsoft diagnostic tool that i think gives that option just a freind has it at the moment so cannt check for sure
- x 6945
I'll need your VIN first to determine what the fault codes mean as they relate to this engine. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
skragamuffin
hi the vin is VF7**************[VIN obfuscated, can be read by forum staff] but as said not yet got my diagnostics back hopefully will be able to get it over the weekend i can pop it on and read any codes thank you
- x 6945
Ok, so let us have the fault codes when you get them.
Your engine code for future reference is AHR (DW10FD Euro 5).
- x 1938
Were there any Euro 5 engine fitted with Adblue? I thought Adblue came in with Euro 6.
- x 6945
This vehicle is a Euro 5 engine, but has Euro 6.1 Emissions Classification, so has the SCR system.
skragamuffin
Hi so I got my diagnostics back and it's read the vine all OK now it's asking what the ECM is a selection of 9 how will I find out this info please
Reason: Falling-over images propped up.
- x 6945
The diagnostic kit should be able to determine this by interrogation of the systems. You actually have a Delphi DCM 6.2 engine ECU.
skragamuffin
Hi here I am again thank you for all your help so far I have 4 codes
P208E
P2A00
P2204
P16EA
I'm thinking a poss faulty nox sensor making the ecu inject too much DEF into the exhaust
But then I'm no expert by fathanks again
P208E
P2A00
P2204
P16EA
- x 6945
P2A00 00 - Concerns the tightening of the NOX sensor.
P20EE: Depollution of the deNOx system: Emission control ineffective. Officially, they will Check to see if the engine management software is up to date and apply this if not.
P16EA: Depollution of the deNOx system: Excess emission of ammonia. There can be a multitude of sub-codes for this fault, so no further info as to the exact cause, but can be the Urea pump, the Urea injector, the NOx sensor or the pump itself.
P208E: DeNOx system circuit: Detection of a blockage. The fix is not known specifically, as this will be determined at the end of the extensive guided diagnostic test (that you won't have access to) undertaken by the dealer with this fault code.
skragamuffin
I forgot to mention that when this first happened it was after abt an hour an a half's driving and when stopped the white smoke was coming from the exhaust and from underneath up near the back of the engine bay kind of manufold area
In ref to your reply to the codes will it need to go to a main dealer
Sorry my response time is slow I'm at work and am doing this on my breaks
