Just done the cv boots and now with the car jacked up and no wheels when I put it in gear and press the throttle it makes a grinding bucking type sound,
Can't figure out where it is, I filled the transmission back up after. Only things changed was the boots.
In gear at idle it makes no sound only with throttle
2014 Citroen dispatch grinding noise
Monger
Re: 2014 Citroen dispatch grinding noise
Both shafts came out when i changed the boots, could they be not in correctly? Hub nut is all tight just no wheels
Monger
Cv joints not greased enough? It's only when it spins the shafts
Monger
Really need help I've re greased the joint but there's still a grinding banging noise coming from the left side, it's only when in gear and pressing the throttle
Monger
When I press on the throttle the left side drive shaft is stopping\skipping???? What causes this, does it need to be on its wheels?
- x 1486
Are you sure it's properly seated in the diff, and you haven't sprung the CV joint apart? It should drive quietly even with the wheels off.
Monger
My right hand side one did separate as I couldn't get the other half out but both seem to be in. as far as I can see they are all in place when, I spin them by hand it doesn't make the noise.RichardW wrote: 18 Jun 2024, 21:06 Are you sure it's properly seated in the diff, and you haven't sprung the CV joint apart? It should drive quietly even with the wheels off.
I can see any obvious gaps left hand is flush with the diff right seems to be OK also
