Where should this part be installed in a C5II car?
sydo
x 9
Unread post by sydo »
Hello friends, where should this part be installed in the C5II car?
Dommo
x 20
Re: Where should this part be installed in a C5II car?
Unread post by Dommo »
I’ve had a look online and a few places are stocking it as a dashboard part, so I’ve looked on catcar and it looks a bit like part 19 or 20 on here. Something to do with the hot air vents system by the sound of things?
http://www.catcar.info/citroen/?lang=en ... aWVyPT0%3D
x 1056
Unread post by wheeler »
Dont think its any of those parts, going by the colour of it i would say it's an externally mounted part, likely part of the under body protection.
PaulC5
x 675
Unread post by PaulC5 »
Searching on the part number on it suggests it is part of the interior trim https://www.ebay.co.uk/itm/115599579113
x 6957
30480M is not a valid PSA part number. It's not shown for any vehicles, as we already checked that. :wink:
The seller is also just using the number etched on the item, but it certainly isn't a valid internal or external number for parts. I've had a job looking / identifying it so far.
Steve Walsh
x 516
Unread post by Steve Walsh »
x 1454
Unread post by xantia_v6 »
It looks like something that might go on the seat base.
x 3306
I think it might be part of the ventilation plastics. If I am right, there are 2 similar parts (but mirrors of each other) down low on the centre console (possible codes 7588TK and 7588TL). To re-fit it you will first remove the long 'tunnel' plastic (7588YT) between the front seats. There should be a screw to hold the duct in place.
I hope that I am right, and that this helps.
