Help required Identifying what 207 gear linkage cable
loafin_about
Re: Help required Identifying what 207 gear linkage cable
Hi all, after spending a good few hours in a carpark (albeit my favourite beachside one) waiting for a tow the other day the diagnosis is new gear cables required for my 2009 207 SW with the 1.6 hdi.
The mechanic has quoted $1000 AUD ( £530 odd) plus fitting and a 12 week wait. Given the car is 15 years old that repair is not sounding worthwhile.
He quoted part 2444CZ and I have found genuine online for $275AUD excluding freight and if I can access the members area I may well tackle it myself. https://alvadi.ee/en/kataloog/varuosa/90838604/?sv=1
Earlier I tried to renew my donation status but not sure that it completed.
Can admin please check two things:
1) is this the correct part number for my VIN - VF3**************[VIN obfuscated, can be read by forum staff]
2) did the donation complete?
Thanks from Australia!
2009 207 SW 1.6 hdi
1958 Series I Morris Major (my first car...)
SW Western Australia
loafin_about
Just found a Borg and Beck aftermarket for $200 AUD (~£100) delivered...
https://www.ebay.com.au/itm/335335486615
2009 207 SW 1.6 hdi
- x 6954
How did you make your donation? - there's no record for a Paypal donation, as this would automatically upgrade your membership. I've also checked the logs and there's nothing showing up via PayPal so far. Australian Dollars 19.61 at today's rate. Any issues or queries, just send me a Private Message.
loafin_about
I tried doing it through the donation page and after selecting the amount it went through to my PayPal homepage but I don’t see it on my transaction record. I’ll try again. Thanks
2009 207 SW 1.6 hdi
- x 6954
Thanks for your Forum Donation.
All sorted - as you can see you are now in Green!
Ok, so back to the cables:
(2) Gear Selection Control Cable
New OEM Original part: 2444CZ, £278.40
Cheaper PSA Alternative option, part: 1684694580, £145.56
These are obviously UK prices with our 20% VAT included.
- x 6954
As I read above you may need some help, give me 20 minutes to put together a procedure, then I'll provide the link here for you when I've finished it.
loafin_about
Marc you already have a procedure earlier up the post.
viewtopic.php?t=69994
2009 207 SW 1.6 hdi
- x 6954
- x 6954
That's not the correct one!loafin_about wrote: 14 Jun 2024, 13:01 Marc you already have a procedure earlier up the post.
That procedure is specifically for the 'MA' type gearbox, not the 'BE4R' type that you have.
loafin_about
Great, amazing service as always Marc - although the first incorrect procedure looked a bit simpler!
2009 207 SW 1.6 hdi
loafin_about
The alternative part, 1684694580, is that still a genuine PSA part? I’m not finding many hits when I google it.GiveMeABreak wrote: 14 Jun 2024, 12:47 Thanks for your Forum Donation.
snip
I will probably just go an aftermarket one - perhaps Borg and Beck if they are considered reasonable.
2009 207 SW 1.6 hdi
- x 6954
Yes, it's a cheaper Peugeot approved official part and is listed underneath as an alternative.
As long as you match up the OEM part or the other part I have provided, you should be fine.
loafin_about
Do the cables just pop off the ball joints? I don't have the correct tool but surely it is just a piece of sturdy metal or plastic with a 10mm gap you use to lever them off? I have fashioned something to suit. Access is not great but unsure how much force to apply.GiveMeABreak wrote: 14 Jun 2024, 13:27 Here you are:
Peugeot 207 Gear Control Cables - Removal & Refitting
2009 207 SW 1.6 hdi
- x 1055
An open ended spanner does the job of the 'special tool' just find one that is just a tiny bit bigger than the ball, slide it under & pop it off. Dont know what your one is like but some gear cables have a button on the top that needs pressed in to release it from the ball joint, normally this type just lift off without any levering when the button is pressed in.loafin_about wrote: 28 Jun 2024, 09:03
loafin_about
Thanks wheeler. I had a quick look and there is no button but i I like the spanner idea!
Should get a chance to try tomorrow.
2009 207 SW 1.6 hdi
