Hi All,
I have a Peugoust 5008 203 1.6 HDi with a ECG gearbox
A couple of weeks ago I got the "Gearbox Faulty" message on the display followed by it being impossible to shift into any gear.
Selecting any gear briefly flashes the selected gear on the display (R, A1 etc) before dropping back to N
I haven't checked the actuator fluid not sure how I can do this I am hoping to drop the car off at the mechanics very soon. Could this be simply low gearbox oil level? I didn't see any obvious leaks.
I have Diagbox and getting fault code is P0868. A quick search here points to low hydraulic oil pressure.
I’ve attached a screenshot as I don't fully understand it.
Any suggestions or pointers for further analysis would be greatly appreciated
Thanks in advance
Peugeot ECG Can't change gear - P0868 - oil deficit fault
vmguru
- x 6950
Re: Peugeot ECG Can't change gear - P0868 - oil deficit fault
Pop your VIN up so we can see the system you have. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
In the interim, it's likely these will be relevant:
| Fault Code: | P0945 |
| Description of Fault: | Electro-pump unit electric motor control fault : Short circuit to positive. Description of the diagnostics: Possibility 1 - Pressure sensor fault Possibility 2 - Short circuit to positive; The pump is stopped Possibility 3 - Incoherence between activation of the pump and variation in pressure. Context of appearance of the fault code:
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0868 |
| Description of Fault: | Oil pressure deficit fault: Pressure too low. Hydraulic pressure too low. Context of appearance of the fault code: The following conditions have to be met: - Ignition on - The starter motor is not operating - Absence of gear changing Technical precision on the context of appearance of the fault code: The pump is operated No fault coming from the oil pressure sensor |
| Symptoms: |
| Suspect Areas: |
vmguru
VIN: VF3**************[VIN obfuscated, can be read by forum staff]GiveMeABreak wrote: 13 Jun 2024, 12:03 Pop your VIN up so we can see the system you have. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
- x 6950
Okay, it's as I thought, so code descriptors are as above.
It really needs a dealer check here as these systems are specialist and need specialist knowledge to deal with to be honest. It may be that checking the actuator oil levels if too low may solve the other issue - so that's a first step. The oil level can be seen on the oil level bottle on the system - but you you cannot just top this up, as the system MUST be depressurised first before the oil quantity is checked and refilled, which requires professional level diagnostics and special oil.
So my advice would be get it to a dealer as they have all the equipment and this may save money in the long run taking it from garage to garage (for those who will even touch these).
vmguru
Thanks I think this is beyond my basic car mechanic knowledge, I have heard so many bad things about these EGG gearboxes just going to get it fixed and get rid of this car.
Reason: Removed Quote - No need for previous post
vmguru
I ran Diagbox to check the Hydralic pressure of the gearbox I can see when the car is in N it seems to be bouncing between 38 bars to 60, it shoots up and slowly comes back down (screenshot attached)
When I change gears I can see this pressure bar dropping to 20 and then shoots back up to around 60 basically bouncing between 20 to 60 bars (screenshot attached)
vmguru
is there anything that I could look at? perhaps it needs a top up of oil? it would be useful to see diagram of the ECG gearbox and its components I can see there is a reservoir is this something I can check for fluid levels?
- x 1481
If the pressure is bouncing around, I would guess the the fluid has leaked out and the pump is mostly pumping air.
Look for oil stains.
vmguru
Thanks I had a quick look from the top of engine couldn't see anything all seems pretty dry I am planning to tow the car to the mechanics tomorrow his pretty familiar with these ECG gearboxes most mechanics don't understand them and do not want to touch them.xantia_v6 wrote: 13 Jun 2024, 13:10 If the pressure is bouncing around, I would guess the the fluid has leaked out and the pump is mostly pumping air.
vmguru
I have managed to locate the reservoir does look like I have a leak somewhere. The current level is just below the minimum, I wonder if I could top this up which would allow me drive this to garage instead of towing it
- x 1498
The level is only correct when depressurised, however if you switch the ignition on and it goes down to almost empty then sticking a bit more in might work.
vmguru
Any ideas what the specification of oil I need? I cannot see Eurocarparts or GFS selling itRichardW wrote: 13 Jun 2024, 18:20 The level is only correct when depressurised, however if you switch the ignition on and it goes down to almost empty then sticking a bit more in might work.
- x 6950
You need this: https://www.ebay.co.uk/itm/166098390783 ... d_source=1
vmguru
Thanks that's seems very expensive for 1L of oil, will have a look around see if I can find it at more reasonable price, the specification from what I can see is "9979A4"GiveMeABreak wrote: 13 Jun 2024, 20:17 You need this: https://www.ebay.co.uk/itm/166098390783 ... d_source=1
same stuff but cheaper https://www.ebay.co.uk/itm/324989317747
vmguru
From what I can see Comma AQ3 meets the 9979 A4 specification and GSF sell this for £10.37, GSF is very local to me I will double check with them in the morning.
https://www.commaoil.com/passenger-vehi ... s/view/191
https://www.halfords.com/motoring/engin ... 24309.html
