c5 x7 anti pollution fault
Agour
(Donor 2026)
x 8
Unread post by Agour »
Hi all,
I had the dreaded anti pollution fault flash up the other day.
Stayed on for 20 minutes - then I left the car for an hour or two.. and hasn't been back since.
Finally got a lexia and plugged it in, but I can't seem to find the fault code for it.
I found a few other codes - but nothing that should be related?
Any ideas where to find it in the software?
Thanks!
x 1503
Re: c5 x7 anti pollution fault
That's in the BSI, you need to look in the engine ECU.
Agour
(Donor 2026)
x 8
RichardW wrote: 05 Jun 2024, 10:43 That's in the BSI, you need to look in the engine ECU.
I guess that would be "engine relay unit"?
I can't see anything else labeled with engine
x 1503
Once in Diagbox and it's read the VIN click on fault finding and then let it do a global scan. The engine ECU is usually the second one in the list, may be called injection or something like that. If you post up a pic of the global scan results, we can tell you which it is.
Agour
(Donor 2026)
x 8
Got it, thanks! :)
2 faults under the injectors, presume it must be p1166 that caused the anti pollution fault?
steveclv
x 40
Unread post by steveclv »
I can't help but I just noticed all your fault values (bar for example) compared to mine which had the same fault - we must be related LOL
x 6950
The faults are at least for now, intermittent, so I'd just clear those down and see how things pan out.
When did you last change the diesel fuel filter?
Don't run the fuel tank too low.
I'd also suggest getting some fuel system cleaner in for the next few tank-fulls and that should give the fuel system a clean, or start using some premium diesel for a while.
Agour
(Donor 2026)
x 8
steveclv wrote: 07 Jun 2024, 21:44 I can't help but I just noticed all your fault values (bar for example) compared to mine which had the same fault - we must be related LOL
did you sell your car recently? :lol:
Agour
(Donor 2026)
x 8
GiveMeABreak wrote: 08 Jun 2024, 10:19 The faults are at least for now, intermittent, so I'd just clear those down and see how things pan out.
thanks, will do!
I haven't swapped it, car is new to me.
It was full main dealer service history - so I imagine it was done at most intervals.
But I'll do it soon to make sure :)
Will get the cleaner in the tank too, thanks!
x 6950
Ok, so the fuel filter is changed every 20k miles officially.
x 2008
Unread post by Stickyfinger »
GiveMeABreak wrote: 09 Jun 2024, 22:09 Ok, so the fuel filter is changed every 20k miles officially.
Fuel filters are like Cabin Filters.....officially/allegedly.
After "getting into" my C5x7 (years ago) that had a full dealer service history I will NEVER trust a Main Dealer service record OR that the work they did was done or IF it was, that it was done correctly/safely (missing suspension bolts etc)
