2017 1.6 hdi oil/diesel under engine cover (Peugeot 2008 120bhp)
x 8090
Re: 2017 1.6 hdi oil/diesel under engine cover (Peugeot 2008 120bhp)
That sounds like the same issue I had with my C5 when I first got it. Lots of fumes and gunky oil round the injectors. I cleaned it all with carb cleaner and re torqued the clamp bolts and had no further trouble in the next 45000 miles after which I sold it! :-D
308sw
x 14
Unread post by 308sw »
Was yours an 8 or 16 valve version?
x 8090
16V :-D
x 1939
You may have two problems. A loose injector clamp, giving you the exhaust smell, and a separate oil leak which is unconnected to the exhaust smell.
x 1939
In fact the exhaust smell could be from a number of places so may not be the injector at all!
308sw
x 14
Thanks for your suggestions. I removed the air filter box and there is this same oil/diesel/carbon all over the components under the air filter box. Do you think this is all caused by an injector clamp being loose?
Do you know what the thing at the bottom is?
I think these are the middle injectors
x 8090
Could well be, as I said mine was!! :)
x 1939
I don't see how it could be. On the 16v engines the injector goes through the cam cover before going into the cylinder head. It's when the seal between the injector and the cam cover is compromised that you get oil leakage. It's simply not possible on the 8v engines as the injector doesn't go through the cam cover.
