Citroen C3 1.1 - thermostat housing body bolts torque ?
longgo
x 3
Unread post by longgo »
Hi fellas!
In some near point (end of the week perhaps) , I have to replace leaking thermostat housing of Citroen C3-mkII 1.1 engine. I think is TU1A engine. About 60-ish horses and one monkey riding the beast.
The body look like that:
and it is made from some aluminum alloy. The thermostat body is plastic.
My question is about the bolts tightening torque. In the replacing manual inside the Citroen database it only show the order of replacement.
In some other manual related to C2/C3 found that one:
Unfortunately my small "regular" torque wrench start from 10Nm up to 25Nm and my electronic adapter I think is from 5Nm up to 200Nm (if I can trust it..)
So, is that 8Nm true? Even the plastic valve cover torque is about 10-13Nm.. Sure, some lock compound will be applied but anyhow that seems quite light tightening..
Thank you in advance for your contribution on the topic
ozvtr
x 230
Re: Citroen C3 1.1 - thermostat housing body bolts torque ?
Unread post by ozvtr »
There are two types of thermostat housings Plastic and aluminium. Then there is the thermostat outlet, that's always plastic.
The plastic housings have rubber gaskets embedded in the mating face of the housing. The aluminium housings need RTV to seal them.
You will need to ensure the mating surface of the cylinder head and aluminium thermostat housing are flat. Use a thin bead of RTV on on the thermostat housing face only.
8Nm is 70 in/lbs. If I recall, the bolts are only M5, over torquing them may damage the threads in the cylinder head
Engineering spec for M5 bolt is 8Nm.
I don't know what you mean by "the plastic valve cover". What plastic valve cover are you talking about?
longgo
x 3
In the first post I mentioned that the housing body is made from Aluminum and I doubt a bit that the bolts are M5 because the holes for them in the body are 8.3mm in diameter.
They are just perfect for M8 to pass through, and if indeed they are M8 - then 8Nm should be quite low in my opinion..
Together with that part in the package arrive some soft polymer gasket for the body. No RTV or silicone should be applied in that case.
You`re right, the thermostat outlet is plastic with already rubber O-seal mounted. It screws are M6 in size and because is plastic make sense to be tighten about 7-8Nm..
As for the "plastic valve cover" I mean exactly valve covers.. (valve, camshaft, on top of the engine head..) Some models as Citroen C5-mk2 2.0 engine, or VW Passat 1.9TDI , Fiat Punto 1.2 or.. (put your model here) have M6 or even M8 bots to hold that cover and there is 10-15Nm of torque to be applied. That`s why I was wondering if the big aluminum housing have holes (and perhaps bolts) M8 how much will be the torque?
For sure the gasket should be not overtight ... so shall I use the average momentum for M8 and then reduce it with 20% and go ahead... :o
ozvtr
x 230
longgo wrote: 03 Jun 2024, 21:27 As for the "plastic valve cover" I mean exactly valve covers.. (valve, camshaft, on top of the engine head..) Some models as Citroen C5-mk2 2.0 engine, or VW Passat 1.9TDI , Fiat Punto 1.2 or.. (put your model here)
I'm sorry. I was laboring under the misapprehension that you were talking about PSAs 1.1 TU1 engine as installed in the Mk2 Citroen C3. But apparently you are not. My bad. :lol:
longgo
x 3
You where right! The bolts are indeed 6mm...
Then it make sense this 8Nm quoted torque , but for me it make nonsense why the holes in the casting are made 8.3mm :shock:
Thanks for the participation!
ozvtr
x 230
Well, I wasn't exactly right, so I wont take any credit. :lol: But I did remember that they weren't very large diameter bolts.
I removed an aluminium thermostat housing from a TU3 cylinder head to get some machining done to the head. All of the resources that I could find said the housing is sealed back onto the head with RTV. So that's what I did. Again, from my references there was no gasket (the same as your diagram). I used the Citroen's mechanics hand book and doc backup for the torques (what ever they might have said-cant remember). And that housing has not leaked.
I am certainly NOT saying DON'T use the gasket. It's just that you cant buy a gasket without buying the kit, as you did.
As the table says there are 8 of those bolts clamping the housing and I guess they (PSA) are going for large(ish) numbers of bolts at a low(ish) clamping force rather than a few bolts at high clamping force?
Just for the kiddies playing at home, the thermostat housing has two separate chambers. Of course there is the cylinder head coolant outlet chamber. But also A chamber that covers the end of cam shaft and the camshaft retaining clamp. So the housing has to seal against oil and coolant.
longgo
x 3
Actually, you been right! The bolts where in matter of fact 6mm ..
The original unit been made from plastic and there was small gap contour made where the RTV to be applied. As bonus seems oil and water been in contact because crack on that plastic shell.
Just for the protocol, that pipe marked with red marks is kind`a on the way and is difficult to work on the part. To get it a bit sideways one must remove the bolt that hold it to the engine block (red arrow) but to access that bolt the starter motor must be away.. :-D Sure, I did not remove them..
The new one is made from alloy and come with a gasket. There isn`t any special area that the RTV should fit:
The bolts I tight with 10Nm on my not so precise torque wrench.
ozvtr
x 230
longgo wrote: 17 Jun 2024, 09:10 Just for the protocol, that pipe marked with red marks is kind`a on the way and is difficult to work on the part.
Yes, that's the water pump inlet from the radiator. There is one screw on the back of the engine block. You can also remove the inlet manifold to get to the screw too, but not fun.
longgo wrote: 17 Jun 2024, 09:10 The new one is made from alloy and come with a gasket. There isn`t any special area that the RTV should fit:
Someone went to town with the RTV!!
From the factory the alloy thermostat housings are sealed with RTV. From the factory the plastic housings have an integral rubber gasket. If you buy an after market version, well, you get what you get I guess.
But either way the plastic housing shouldn't need RTV!
longgo
x 3
ozvtr wrote: 18 Jun 2024, 12:53 You can also remove the inlet manifold to get to the screw too, but not fun...
Personally, didn`t bother - just slightly push the pipe, the rubber hose was removed and after removing the old unit, put the new one
ozvtr wrote: 18 Jun 2024, 12:53 From the factory the alloy thermostat housings are sealed with RTV. From the factory the plastic housings have an integral rubber gasket. If you buy an after market version, well, you get what you get I guess. But either way the plastic housing shouldn't need RTV!
Well..it was with some sealant despite should be with rubber gasket. The new part contact surface was made straight.
Not as water pump for example, or some cover that have small groove on it where the sealant will fit. Maybe on the OEM part is a bit different..
Anyway, both pictures are from the process and so far so good.. The car still move around.. :)
