Cam belt change
Vic Evans
x 178
Cam belt change
Unread post by Vic Evans »
My wife's 2014 c4 1.6 hdi Millenium is due a 10 yearly belt change so presumeably it would be best to get the water pump changed at same time. It will be done by local Citroen garage. Any other things she should be asking to be done at same time as she intends keeping car. ? It's done about 105,000km.
Can't get vin no as she's away with car at the mo. but it was given here if it helps,
Vic Evans wrote: 07 Nov 2019, 15:03 Thanks HR5543
VIN is VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
cheers
x 6950
Re: Cam belt change
Hi Vic, unfortunately as the vehicle is 25 years old, Peugeot don't have the servicing data available online so I can't provide you with the details of servicing operations and schedules for this vehicle.
But brake fluid should be changed every 2 years and the cooling system checked for coolant effectiveness if it hasn't already been done.
Vic Evans
x 178
Re: Cam belt change
Wotcher Marc.
I think you're confusing me with somebody else or I gave you a vin ref to my old pug.
I'm talking about a 10 year old Citroen :-D
x 6950
Re: Cam belt change
Ok, so I may have your older vehicle obviously :-D Best to pop up the latest one here as quote's with a VIN from your post above are permanently obfuscated (the characters are as you see in the quote), so I can only see the VIN from the original post. :wink:
Vic Evans
x 178
Re: Cam belt change
GiveMeABreak wrote: 30 May 2024, 11:17 Ok, so I may have your older vehicle obviously :-D Best to pop up the latest one here as quote's with a VIN from your post above are permanently obfuscated (the characters are as you see in the quote), so I can only see the VIN from the original post. :wink:
vin for 2014 C4 is VF7**************[VIN obfuscated, can be read by forum staff]
x 6950
Re: Cam belt change
Ok, that's more like it (and just for ref. - there are no letter 'O's in the VIN, just Zeros :wink:
Here's the servicing schedule:
Click Image to Zoom
Vic Evans
x 178
Re: Cam belt change
Thanks marc.
Great service as usual
Vic Evans
x 178
Re: Cam belt change
Mme just picked up car from garage after service & cam belt change etc.
Was paying bill when owner, who's looked after our cars for 21 years, came out & gave her the old belt pulley which apparently was almost off. He had never seen this before & said she was lucky the engine wasn't wrecked.
x 2008
Re: Cam belt change
Unread post by Stickyfinger »
Ohhhh, that was a CLOSE one !
Vic Evans
x 178
Re: Cam belt change
Can somebody tell me where this pulley is from?
It's got a key slot so I'm guessing it's either from the crankshaft or camshaft.
x 6950
Re: Cam belt change
It's the engine timing gear that's on the crankshaft pulley, item (7). £90.68 UK inc. VAT (£75.57 ex VAT) just for comparison.
Vic Evans
x 178
Re: Cam belt change
Cheers Marc
Garage charged me 97 euros inc 20% TVA (VAT) for the part which is about 84 quid so certainly not a rip off.
Mme & car had just returned from a trip to the UK so it would have been a disaster if the belt had broken whilst she was en route.
Car's running like a good'un now with 2 yearly Controle Technique (MOT) due early next month.
x 6950
Re: Cam belt change
I'm sure it will sail through!
