Xantia 2.0l HDi S reg
stevestix8
x 13
Unread post by stevestix8 »
Hi All,
Been a while again since posting and the car is doing well, over 25 year old now.
Quick post to see if anyone has suggestions:
I pushed the down button on my electric window (driver side) about a week ago and it started making a whining sound, but the window still went down and up again.
Yesterday was over doing some jobs and cleaning the car and I pushed the button to lower the window and nothing happened (except the sound of the window motor working).
Have done some research and is probably either a cable broken or its come of its rails? The good thing is the motor still sound like it works (and the window does stay up on its own).
Has anyone had this problem before? Am going to remove internal panel and investigate but am wandering if I should order parts first, i.e. if its probably a broken cable?
Any suggestions?
Steve
x 6956
Re: Xantia 2.0l HDi S reg
Yes, sounds like the regulator cable - water gets in the channels and eventually rusts the cable - then one gloomy day when it's chucking it down, you're at the automatic ticket barrier wind the window down to get out and snap, it won't go up again.
The door card needs taking off and the regulator mechanism replacing.
Stewart(oily)
x 35
Unread post by Stewart(oily) »
The cable ends in a plastic moulding, these can snap, I found a replacement on ebay for £3 or so and was pretty straightforward, the cables were fine.
stevestix8
x 13
Hi Gents,
Thanks for responses, certainly true the window will do it at the worst time.
Have been reading (and watching vids) that confirm it is most likely the plastic moulded 'regulator clip' part, it didn't sound like the cable snapped, just whined then the button stopped moving the window, but can still hear window motor going.
Have found 3 options on ebay:
1: Regulator clip only:
There appears to be 2 different types (different design):
https://www.ebay.co.uk/itm/133772921330
https://www.ebay.co.uk/itm/134117551845
2: Cable kit:
https://www.ebay.co.uk/itm/144940272367
I can see from the cable kit that the regulator clip (for my variant of car) is the 1st regulator type (dark grey), and you are right about it costing about £3.
Have ordered and will get it sorted, many thanks.
Steve
stevestix8
x 13
Hi All,
Further to my last post I have now had the door panel off and done some investigating.
It turns out it was the cable rusted through. Have removed slider arm and old wires.
Have ordered some new cables £8.00, link below, and the regulator clip arrived today (£2.99).
https://www.aliexpress.com/item/1005002971820937.html?
So I should have everything I need to fix the window mechanism, there is a great post on here about how to do it, and I removed the arm today, so am hoping it should go well.
On a side point, during the door panel removal I must have knocked some of the wires out of the electrical block that goes to the back of the window switch and have now also got to reconnect some wires into the grey coloured block that plugs into the switch, see pics of grey block below (not my car just an example).
I know which order the 5 wires go in and what way up the block goes but does anyone know how to open these blocks up to reconnect the wires? Have never seen these connector blocks / plug to switch before but there must be a way of opening them up to reconnect wires?
Any help appreciated,
Steve
stevestix8
x 13
Hi Again,
Just to answer my own question, I have found out how the connector block that plugs into the back of the switch comes apart, see pic below:
Am waiting on the cables for the window mechanism and have got about 4 jobs lined up to do on it, should get it all sorted again in a couple of hours.
Thanks for any advice.
Steve
stevestix8
x 13
Hi All,
Just quick post to say all jobs done and finished on it today (have been busy with my business).
I wired the switch and only blew 1 fuse, in my 'trial and error' method of getting the right wires in the right holes. (I got 5 new 30amp fuses so I had a few attempts lol).
Once the elec block was wired in again and plugged in to the motor to test, the switch (and motor) now works as it should.
I then installed the window mechanism (arm) with new cables and slider in to the car door, and it went well. The regulator popped in the hole in the glass nicely, then clipped to secure. Glass running smoothly in runners.
Thanks for advice, car all ready for another year.
Steve
LHMfanatic
Unread post by LHMfanatic »
My Xantia is a 1.9td, mk2, and the electric window has today come off. I've disassembled it, and no rust- but the cables have fouled themselves. I've removed them, but I can't figure out how to refit them. The Haynes manual is pants...
stevestix8
x 13
Hi,
Dont think youll be able to reuse those cables if they all creased up and mangled.
You can get new cable set for about £8.00 (I got mine of ali-express) and new regulator ( for a couple of quid).
They just long enough to lock in regulator 1 end then round tensioner and round main spindle in to seat. Same for top end (except without tensioner).
If your not sure then take the working 1 out of the other side of the car and match it (but in reverse).
Is annoying but very satisfying when its fixed lol, Good luck
