What Glue to use for Trim
All the sticky threads from the Citroen and Activa forums have been relocated here at least on a temporary basis.
AndrewH
Unread post by AndrewH »
A piece of trim fell off - see pictures. Luckily, on my drive and not on the road.
Could someone advise how to remove the old glue, and the best stuff to use ?
x 8129
Re: What Glue to use for Trim
Hi Andrew,
That looks to me like it has a locating Tab at the top and a stud fixing at the bottom which has presumably broken and hence it fell off. I think the grey stuff is there to stiffen it and so should be left. I'd put it back on with double sided badge tape like this: https://www.ebay.co.uk/itm/264890492683 ... BM5ovb5_dj
Good luck ! :)
x 6945
It's likely to be a complete part like this otherwise... so hopefully some very strong adhesive to secure that on may do.
AndrewH
Thanks for your input !
