Which Cruise-control stalk
NickCUK
x 3
Unread post by NickCUK »
Thinking about buying a cruise-control stalk for my 2006 1.6 307 but not sure which on to get.
Parts list shows 6242.Z9 as cruise-control only and 6242.Z8 as cruise-control & speed-limiter.
However Aliexpress list 6242.Z8 as 6-pin and 6242.Z9 as 8-pin although both appear to do cruise-control & speed-limiter.
Is it likely to be safer to get the 8-pin one even if the extra pins turn-out not to be used?
x 1485
Re: Which Cruise-control stalk
It's likely you haven't got the necessary throttle pedal to run the limiter, but the two position switch should still work. You may find that your ECU doesn't support cruise however...
NickCUK
x 3
RichardW wrote: 17 May 2024, 16:17 It's likely you haven't got the necessary throttle pedal to run the limiter, but the two position switch should still work. You may find that your ECU doesn't support cruise however...
Is there any way I can test to see if my throttle pedal supports speed limiter or not.
x 1485
Post up the VIN and we can look it up
NickCUK
x 3
RichardW wrote: 17 May 2024, 17:31 Post up the VIN and we can look it up
x 1485
It doesn't have the limiter enabled pedal.
NickCUK
x 3
So am I correct in thinking that I need to get a 1601.Q6 throttle pedal for it as well, is that the right part number? Is the wiring the same, seem to recall when I checked before that it had a 4-pin connector.
NickCUK
x 3
So which cruise-control stalk do I get the 6-pin one or the 8-pin one?
https://www.aliexpress.com/item/1005005986606149.html
NickCUK
x 3
Any ideas which stalk I should buy?
x 6956
Just so you don't think I'm ignoring you - I can't provide an answer for you as it's not originally fitted equipment.
x 1056
Unread post by wheeler »
6242.Z9 is indeed for a vehicle without speed limiter function so i would say the ali express pics are wrong.
I have only ever retro fitted CC without speed limiter but my understanding is if you fit the newer stalk (with speed limiter) the CC will still work as it should but you wont get SL functionality unless you have a correctly wired throttle pedal with 'hard spot' & also programmed correctly.
NickCUK
x 3
Purchased the 8-pin one in the end; cruise-control works fine. That was a very cheap enhancement.
