206cc roof issue & fix.
Huskyxantia
x 906
Re: 206cc roof issue & fix.
Unread post by Huskyxantia »
Roof u shape catches, down for auto
Up for manual pull out and twist.
:-D
Nata13
Re: ???????? ? ??????????? ????? 206 ??3.
Unread post by Nata13 »
Good afternoon, please help! We opened the roof manually, drove a couple of kilometers, and something started squeaking when we closed it, and it continued to squeak. They did everything just like in the video. We don't know what to do or how to solve this problem. The roof doesn't open on its own, we don't know why. That's why they tried the manual one, at first the hook wouldn't come off, and then they unfastened some hook like in the video and it came off immediately. And it's hard to get that hook. Thank you very much!
Reason: Text translated using Google Translate.
Nata13
good day, please help! We opened the roof by hand, drove a couple of kilometers, and something started to squeak when we closed it back, and it continued to squeak. They did everything as in the video. We don't know what to do and how to fix this problem. The roof does not open by itself, we do not know why. That's why they tried manual, at first the hook didn't come off, and then they unfastened some kind of hook like in the video and it immediately came off. And it is difficult to hook that hook back. Thank you very much!
Huskyxantia
x 906
What hook ? Sorry i didn't get notified of this post at all, if your on about the catches you can put them back in they only need moving when its either roof in manual mode then put back to set for auto mode. As for all them question marks well , if you followed the manual roof procedure properly then nothing can go wrong.
:-D
Huskyxantia
x 906
Nata13 wrote: 03 May 2024, 23:09 good day, please help! We opened the roof by hand, drove a couple of kilometers, and something started to squeak when we closed it back, and it continued to squeak. They did everything as in the video. We don't know what to do and how to fix this problem. The roof does not open by itself, we do not know why. That's why they tried manual, at first the hook didn't come off, and then they unfastened some kind of hook like in the video and it immediately came off. And it is difficult to hook that hook back. Thank you very much!
Lubricate every piece of rubber on this roof set up dry rubbers can cause this
:-D
Huskyxantia
x 906
Nata13 wrote: 03 May 2024, 22:55 ?????? ????, ??????????, ????????! ?? ??????? ????? ???????, ???????? ???? ??????????, ? ???-?? ?????? ????????, ????? ?? ??????? ??, ? ??? ?????????? ????????. ??? ??????? ???, ??? ?? ?????. ?? ?? ?????, ??? ?????? ? ??? ?????? ??? ????????. ????? ?? ??????????? ???? ?? ????, ?? ?? ????? ??????. ??? ?????? ??? ??????????? ??????, ??????? ?????? ?? ?????????, ? ????? ??? ?????????? ?????-?? ??????, ??? ?? ?????, ? ?? ????? ?? ?????????. ? ?????? ???????? ???? ??????. ??????? ???????! That's a lot of ? what im seeing
:-D
