1.6 THP Engine oil leak
Aesud
Unread post by Aesud »
Hi!
I have a Citroën ds3 from 2013 with the 1.6 THP engine and I have an issue with oil leakage. I have localized it from a hole on the luft side of the valve cover (see picture). What does this hole do and does anyone know why it’s leaking oil from it?
x 1342
Re: 1.6 THP Engine oil leak
Unread post by xantia_v6 »
That hole does not have any useful purpose, but it doesn't penetrate all the way through, so cannot leak oil. It is however common for the camshaft cover to get a hairline crack in that location that causes an oil leak that appears to come from the hole.
The only cure I found was to replace the whole plastic cover.
Aesud
Oh ok, that explains why there is oil in the gap between the valve cover and the cylinder head. Probably need a new valve cover then.
Thank you!
