C4 B7 Semi-Automatic Gearbox Oil Specifications
pablo95
x 7
Unread post by pablo95 »
Hello everyone, im about to change the gearbox oil on my 2014 C4 1.6 e-hdi 115 (9HD) semi-automatic (BVMP? or EGS6? still dont know the difference) 8-[
After some research i found 2 different opinions:
1) Citroen suggests TOTAL 75w80 ?
2) Some owners suggest 75w !
The second is fully synthetic, the first one, not. Whats the correct oil for my gearbox?
I live in Greece so the car is driven on mostly hot climate.
VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Found also this: https://www.mobil.com/en-fi/passenger-v ... cRIBhJnvIw
x 6955
Re: C4 B7 Semi-Automatic Gearbox Oil Specifications
Your RPO code is 13813 (3 September 2014) so choices are:
MOBIL GEAR OIL FE 75W (Between the 01/01/2012 and 31/05/2015 or between the RPO numbers 12837 and 14083)
or
TOTAL TRANSMISSION HBVFE2 75W From RPO number 12837 (1 January 2012)
Ammonia2418
Unread post by Ammonia2418 »
Hey
Did you manage to change the oil successfully?
I have the same Semi Automatic car and I am looking through the Citroen Manual on how to do this and all I can see is
Oil capacity gearbox empty : 1,9 ± 0,15 litres.
Oil quality : ESSO 75W80 EZL 848 or TOTAL 75W80 H 6965.
Check the oil level : No check of oil level (*).
Lubrication interval : Lubricated for life.
There is no check of oil and it says Lubricated for life (which I dont trust anyway).
Also, I am wondering if this is the BE4R Gearbox from the Citroen Documentation?
How did you manage to drain and refill it? You have any pointers I would appreciate that.
x 6955
Look, it's the same as a manual gearbox - so if you ware wanting to change the gearbox oil (not the hydraulic actuator oil) then treat it the same as a manual gearbox. It's not in the manual because it is not a service operation. You'll need to measure the amount drained and refill with the same quantity, or drain the lot out and refill. To ascertain the quantity for a drain and refill, it will depend on the type of manual gearbox you have.
Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff and I'll be able to advise.
Ammonia2418
Thanks a bunch mate. I actually managed to find in the Manual where to drain it, see attached picture
I do appreciate all the help mate, thanks a bunch.
Ammonia2418
Good morning!
Did you manage to get any info on my VIN yesterday?
x 6955
You have an MC gearbox type, so according to my info it should be:
Quantity of oil to fill after draining: 2,1 ± 0,1 litres.
Quantity of oil to fill after an overhaul: 2,2 ± 0,1 litres.
Oil quality: 75W80.
I don't think you have the correct gearbox in your post above...
Ammonia2418
GiveMeABreak wrote: 26 Apr 2024, 12:14 You have an MC gearbox type, so according to my info it should be:
Oil quality: 75W80.
This just sorted out a whole bunch of the confusion I had. Thanks a bunch! You are a gem!
Fejinwales
Unread post by Fejinwales »
Hello, I joined to ask the same question about my car too. The difference is that the oil seal is leaking between the gearbox and drive shaft so although the manual says there's never maintenance required and so gives no information on fluids, I need to know exactly what to get in order to replace it, and the ammount. Pretty sure it's 75w80 and 1.9 litres, but zi need to make sure as to best brand, fully synthetic etc. My vin (from windscreen) is VF7**************[VIN obfuscated, can be read by forum staff]. Model: C4 1.6 e-HDI [115] Airdream VTR+ 5dr EGS6 (Or: C4 Vtr+ E-Hdi S-A)
Gearbox: EAT6 automatic
Fuel Type: Diesel. I hope this is the right place to post this.
Fejinwales
An addition to the above. I think the correct oil may be TotalEnergies Traxium Gear 8 75W-80 Manual Transmission Gear Oil. My local Citroen dealership have oil they say is the correct one for my car but it's in a Citroen container, and not a TOTAL one.
x 6955
Either of the following - or what Citroen have and the same quantities as I posted above in this post:
viewtopic.php?p=798128#p798128
Fejinwales
Thank you. I cannot find exact matches for the two listed above that I can buy in the UK by Thursday, so I will go with the one the Citroen Dealership has, which was advised by the parts department guy and based on my number plate. One has to assume the compatibility will be perfect.
x 6955
Yes, as the brands change frequently that Citroen use.
Fejinwales
Hi again, sorry to be a bother. I just came back from the Citroen dealership and opened the box, this is what they gave me. There's nothing on the labels anywhere saying FE or API GL-4 (as I know I cannot use GL-5). It does say High performance multigrade transmission oil in the small print on the reverse. He told me that this is the oil they would use if they were doing the service. Now I am concerned if this IS the right stuff to use. Any advice would be appreciated.
Reason: Images fixed
x 1936
If you pull at the corner where it says PULL PAGE you should find some more information underneath. Maybe what you want will be written there.
Apart from that the B71 2330 specification will be the final decider.
