engine FAULT replacement needed on citroen ds4 2012[engine checklight
Doo
(Donor 2022)
x 121
Re: engine FAULT replacement needed on citroen ds4 2012[engine checklight
Unread post by Doo »
My wife's C4 was having problems. It turned out she parked under trees at work & bits fell off the trees & somehow got into the "fusebox" under the bonnet. This contains the engine management, but it was the fuses at fault as the contacts had been damp for a while & built up a high resistance connection.
I had to remove the whole thing & pull the fuses, which I cleaned with a brass wire brush and the connections with a very small file (a woman's nail file is ideal).
That was several years ago and it hasn't happened since. I'm not sure if this will help your situation, but it might give you an idea to start with...
Has anyone seen the plot? :?
LOVEMORE
Unread post by LOVEMORE »
Thank you let me check.
afeezdev
Unread post by afeezdev »
I have the same issue in my DS4 car. engine FAULT repair needed on citroen ds4 2012[engine checklight on]
x 6957
Well get it diagnosed.
Then come back once you have something useful like the fault codes if you want some help. At present, it's just like saying "my car doesn't work".....
afeezdev
Re: engine FAULT repair needed on Citroën ds4 2011[engine checklight
I need help to solve this issue on my car. Thanks
x 6957
So you need to get it diagnosed properly as I said above. Do you think we magically know what the issue is? That's what diagnostic scanners are for, to help troubleshoot.
afeezdev
The Error is P12A8
x 1487
Relates to a fault with injector no 3, might need replacement, but needs looking at properly to figure it out.
