Hi All
Am I right in thinking this trim comes away from the main bumper? If so does it come away without removing the entire rear bumper first? Also does this section from a C4 Picasso also fit or is the Grand Picasso unique? Thanks
C4 Grand Picasso Bumper
- x 1463
Re: C4 Grand Picasso Bumper
Looks like it 'just' clips in as no bolts are shown. I suspect it will be necessary to remove the bumper to free the clips without destroying it. Different part numbers on the normal Picasso.
ldare2000
- x 4
This is perfect thanks so much. Its given me the info to pull off. Just pulled off, clips survived but the corner ripped which is fine as removing to replace...... Well once I find one, they are like hens teeth
Mikekaren2
- New User
Can someone please advise me how to remove the front bumper on my 2013 Grand Picasso, the battery has gone completely flat and I need to get into the engine bay to charge the battery. I can't unlock the car with the key or fob.
I am really stuck and would appreciate some advice.
Regards
Mike
Regards
Mike
- x 1463
If you jack it up you can remove the underlay which may then allow you to reach up the back of the radiator and spring the bonnet catch. But you should be able to manually unlock the doors with the key to get access?
