Injectors misbehaving but trying to understand the numbers
Rhothgar
(Donor 2026)
x 221
Re: Injectors misbehaving but trying to understand the numbers
Unread post by Rhothgar »
darbuck wrote: 25 Aug 2023, 12:07 Big time I wilet you know how I go I am going to go after the coolant harness first and work back from there I think. I printed off a the relevant stuff I can find so far and will go from there next.
Sounds like a plan.
Don't labour the engine though. See if it starts and move on if it is not immediately running sweet.
darbuck
x 289
Unread post by darbuck »
Yeah good advice will do.
Darren
darbuck
x 289
darbuck wrote: 14 Mar 2023, 19:33 Hi Lads I ran a diagnostic on the car because she smells fuelly, yes it's the C5 that has all the problems but I bought it thinking it had an injector problem. Can anyone tell me what the us stands for. To me none of the injectors look right numbers wise but I am hopeful if being corrected. No fault codes apart from the glow plug fault but we know that is a ghost code
Hi all, trying to get on top of a fueling issue. Car smokes white badly at mid range RPMS smells fuely at idle. Leak Off is between 20 to 25ml per 3 min interval. A couple of question.the numbers are approximately the same as the image above. I did note timing is retarded by -5 degrees I don't know how relevant it is.
What is the expected leak off on Delphi injectors on a dwb10 engine?
I couldn't get the injectors to code so would this cause the white smoke?
How do I input the replacement injector codes which are the cross referenced type given the ECU won't accept it I think they have an extra digit?
Darren
darbuck
x 289
Ok got them to code using Delphi scan tool. No white smoke far less fully I will take readings later to use as a base condition. Just abody work and a few bushings in the back to do now and then I can finally book her in for NCT 😃.
Darren
darbuck
x 289
I sorted the glow plug light staying on needed a new relay. So now no preheat codes either and light goes off nearly as quick as it comes on.
Darren
Rhothgar
(Donor 2026)
x 221
What are your new readings on the leak-off?
shtu
x 78
Unread post by shtu »
Going back a little to the question about "us" - Microsecond.
https://en.wikipedia.org/wiki/Microsecond
darbuck
x 289
Sorry Roger I haven't had a chance to do one yet but I will over the next week.
Darren
darbuck
x 289
Yeah I had a brain fart on that.
Darren
darbuck
x 289
Rhothgar wrote: 12 Apr 2024, 15:44 What are your new readings on the leak-off?
Hi Roger, finally got to do a leak off 1,2,4 had approx 20ml after minutes and 3 had 25ml. The limit is apparently 37ml according to the fold version of Citroen doc back up I have. So I think we can safely say well within spec. I'm waiting on tyres for the rear and I need to give her a good clean and then it's going for NCT. So on the home stretch after what had felt like a lifetime of work.
Darren
KennyW
x 165
Unread post by KennyW »
Darren,
Your almost there, keep it up.
Kenny
C3 1.4 petrol (SWMBO)
x 2354
Unread post by MattBLancs »
As above, got to be on the home straight now, good luck with the NCT :)
darbuck
x 289
Thanks lads gave the interior a clean last night. Getting excited now 😃
Darren
ekjdm14
x 263
Unread post by ekjdm14 »
Epic read, this one. Epic struggles too, you've definitely earned a sweet running reliable car so fingers crossed that's what you end up with.
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
darbuck
x 289
Thanks ekjdm14 yeah a lot of work and a lot of money, more than the car is worth by a lot, but I know it's going to be good when I am finished.just finished painting the bumpers which got scratched when they were off the car and the rear wheel arch and passenger side rear door which had bit of damage. I made a mistake and bought too big of tyres for the front so I am waiting on a set from my mate. The 225/17/60's leave a gap of 10mm between the arch liner and it needs to be 20mm for the test so no good. apart from that and a wheel alignment she should be ready for the NCT now, hopefully she will pass 🤞
Darren
