406 Repair MFD patch color.
toh
x 5
Unread post by toh »
If you have the same problem with me like this,
LOVE is All AROUND.
toh
x 5
Re: 406 Repair MFD patch color.
You have to find Polarization film. Then, start to repair,
by removing the polarization film on both size of you MFD.
Then cutting "one" of your polarization film according to the size of you MFD .
Stick that one behind the display glass. Then, the front one you have to turn it 45 degree. and cutting it.
The following show the wrong angle.
This one show that the front film has the different angle with the one behind. (45 degree)
Slowly remove the plastic and stick the film to the front of MFD display.
Then,
LOVE is All AROUND.
x 1939
That's an excellent "how to". Where did you get your polarising filter film? I appreciate that you're in Thailand but was it easy to get hold of?
x 5672
Any amount on eBay
Some more here at Science Store
Seem to be plentiful sources.
toh
x 5
Dear Paul-R
Thank you to myglaren. Then now you save alot.
LOVE is All AROUND.
toh
x 5
Everybody is good to DIY?
LOVE is All AROUND.
