x 7164
MattBLancs wrote: 24 Mar 2024, 08:52 As well as good candidate for the "lovely old garages" thread (think already featured previously) is also a good "period correct" match between car and old shed.
Here (via a bit of artistic licence/ my phone's "filters" ) is the car in for inspection at the height of the cold war:
:-D
Nice work Matt "Garages Gallery Ancient and Modern" has indeed featured the "Two Wrestlers" but has no barrier to repetition or images new and old to put before the class of March 2024.
Here's Citrojims former white AX up on the Wrestler's lift.
viewtopic.php?p=672605&hilit=wrestlers#p672605
x 8353
Loving your photo tweak Matt :D
NewcastleFalcon wrote: 24 Mar 2024, 09:10
I have one of Bluebell, my blue AX, up on the lift too. On her first MoT in my care...
x 8353
CitroJim wrote: 25 Mar 2024, 05:29 Loving your photo tweak Matt :D
Found it :D
Zelandeth
x 1593
Unread post by Zelandeth »
Following the irritatingly erratic weather on Saturday it was lovely on Sunday. However my body decided that lumbering with me with a headache threatening to turn in to a full on migraine for a good chunk of the day was a great idea so my productivity was rather limited.
In the quest to get some of the grime and rust streaking off the Trabant, I really wanted to get these covers off the rear pillar vents. I wanted these off to look behind them anyway as I wasn't in any way convinced that these weren't in some way responsible for our water ingress issues.
Surprisingly the first screw actually came out without progress, the second however snapped pretty much as soon as I looked at it.
I wasn't planning on reusing these anyway, so it was just drilled out and re-tapped to take an M5 A2 stainless machine screw instead. With a bit of grease applied to the thread for good measure.
I'm not at all convinced this isn't a point of water ingress.
The seam sealer which attaches the inner section there feels like it's gone brittle just like the stuff on the front bulkhead had, so I'll be giving that a good slathering with some PU sealant when I've got a bit more time and working brain available.
There's a good couple of millimetre gap behind these grills and the surrounding metalwork (there's actually a spacer in there to ensure they do NOT sit flush), so basically all the water running down off the roof is going to run behind the grill and into the chamber rather than being deflected over it as you'd think to look at it. I reckon that putting a seal around the top and sides of the panel might be a decent idea. That way water will largely be kept out of this area.
At least I know I can easily get in here again in future.
Need to get a bit more elbow grease involved in removing that rust staining.
Do have some slight nervousness regarding what the top of that screen surround will be in once the screen is removed. We know that needs to happen as I know the offside lower corner of the surround is holed and the screen needs to come out to fix that. Sure that will be an interesting day. That will likely not be done by me, by the way. That will be entrusted to someone who knows how to fix this sort of tinworm damage.
Don't think I've ever had another car which looks quite so at home in a slightly shabby urban setting.
TPA comes close, but does tend to stand out a bit more just by not being quite normal car shaped.
Current fleet:
Zelandeth
x 1593
Why is the online planning application system such a complete disaster? Vaguely worded and shoddily coded throughout. Everyone loves "continue" buttons that you can't actually click on, and information popups which cover the entire top 1/4 of the screen that can't be dismissed, don't they?
Not to mention the boundary drawing tool where there is no pan feature available while drawing a line. If I'm zoomed far enough out to see the whole site, the snap tool snaps the line to the wrong things. If I'm zoomed in close enough to make that behave, I can't select the whole site because I need to pan the base map...and going to do that resets the line drawing...
Just going to bash my head against a concrete wall for a few hours, I think it would be a more productive and less painful use of my time.
Current fleet:
x 5671
They are probably obliged to provide it but don't want anyone actually using it.
Contact your MP and/or Mayor and make their lives a bit more miserable, that is after all what they signed up for. Probably :roll:
Zelandeth
x 1593
myglaren wrote: 27 Mar 2024, 15:08 They are probably obliged to provide it but don't want anyone actually using it.
Bit late for that given that this is very much my fault anyway. Trying to apply for retrospective permission for something that if it had even crossed my mind would have needed planning permission I'd not have done in the first place. First I knew was when the enforcement notice arrived on our doorstep. All this over a fence we moved by a metre (still within our boundaries). Unfortunately putting it back won't satisfy them either as the removed greenery (which had to come out and start over anyway as it was so utterly overgrown) will "take an appreciable period of time to fully conceal the hard boundary."
Really, really wish I'd never touched things now.
Current fleet:
x 5671
Sounds as bad as US HOA's. Such a performance over what is
a) a triviality and
b) on your land anyway
"Really, really wish I'd never touched things now".
Situation normal here, just got into one of those today. Ten minute job hahaha :evil:
x 3566
Ah, planning applications...... ](*,)
I had to do a FULL planning application to change two double glazed windows - like for like - for my mother's flat.
I had to answer questions along the lines of - how will the development impact the surrounding roads ? Are the trees going to be affected ? Impact on drainage ? etc, etc.
Then the %(**&"£@@##~!.. people at the planning office still managed to miss the deadline and had to ask me for an extension.
You have my sympathy, Zel.
Zelandeth
x 1593
It's just like everything on this house. Every time you get even a sniff of making one step forward you wind up taking two or three steps back. We've been here ten years next month, and I feel like we're drowning in the to do list just as badly, if not more so than when we moved in.
In other fun house news, it appears that the company who did a load of work on our roof has vanished into the sunset. Their phone numbers all go straight to voicemail, and their email addresses all bounce. Basically every Google review for the last six months is a one star one saying "These guys never turn up, don't touch them." Aside from one reviewer saying they're having to take legal action against the company to get issues resolved.
Great. I'm trying to get in touch with them to get a couple of things which didn't survive the winter sorted. Relatively minor in the grand scheme of things, but indicative that they'd done a shoddy job of fitting the final trims and such. Which gives me little confidence in what I *can't* see. So much for the ten year warranty.
Also means I now need to find someone *else* to come and sort this mess out.
Original plan had been to get the same guys back in - after all it only took me about a year to actually get someone to respond to me asking for them to quote for our work and to actually appear. The thought of doing that all over again absolutely fills me with joy...
Absolutely *everything* on this place, no matter how small seems to end up being a giant struggle, and I'm just sick to the back teeth of the sight of it now.
Current fleet:
x 8353
Oh gosh Zel, feeling your pain here, good and proper :evil:
x 5671
Can you trace them through Companies House?
Zelandeth
x 1593
myglaren wrote: 27 Mar 2024, 19:01 Can you trace them through Companies House?
Yes. Though that doesn't help my confidence.
Companies House basically haven't heard from them since April 2022 if I'm reading that right.
Incorporated in 2021 doesn't exactly match the "Family run company for the last 20 years" claim on their marketing materials either...
To be honest, knowing their registered address (which matches what's on their still active website) doesn't really gain me much. Based on the quality of the work that's failed and the last 6 months of reviews on Google, I'm honestly not sure I'd want them to be coming back to do remedial work anyway.
I guess in theory we could get remedial works done as necessary and then push a claim against them through the small claims court - but knowing this type they'd declare themselves bankrupt and wind up the company if they lost anyway so we'd be right back at square one, probably another year down the line and with a legal bill we're left to foot.
Edit: In better news, the Partner is now back from having the noisy wheel bearing replaced. My hunch that it was the nearside front was indeed correct. Will be going in for the MOT on the 4th. Will give the car a once over before then - and a valet as it's currently filthy both inside and out and I really hate taking cars in which aren't clean and tidy.
Current fleet:
Zelandeth
x 1593
Few little bits and pieces done this afternoon, but nothing particularly ground breaking.
The Trabant has never been particularly fond of idling smoothly (even by two stroke standards), but it was definitely better after changing the blown head gasket. Today I had the thought of using an IR thermometer to compare the two jugs to see whether both cylinders were properly contributing. Imagine my surprise when I pointed it at cylinder number 2 and realised that the spark plug was moving.
Yep, it wasn't even finger tight and I was able to turn it about two turns tighter by hand. With that tightened up the idle seemed to be a good bit better, though I've not actually done a test drive to get it properly back up to temperature since. Wish all fixes were this easy.
On the Rover I had a few small things I wanted to look in to (as I didn't feel up to wrestling with the oil pump housing today).
The windscreen washers worked once but have resolutely refused to do anything ever since. Think I'm going to have to give in and just buy a new pump there as everything *seems* fine and it's not full of slime, it just refuses to pump. I think the little rubber vanes have probably either gone too hard to work or have perished. Plus the motor only seems to run about 50% of the time unless I whack it with a screwdriver. The bottle is cracked and can't be filled more than about 1/3 anyway so hopefully I can find a whole replacement for not stupid money.
I knew something was up with either the headlight switch, circuit or way the switch was hooked up. This was because as soon as you clicked the switch to the first notch, which should be side lights, you got side and headlights - exactly the same as when set to the correct headlight position.
Yes, that would do it.
With this jumper wire removed everything appears to work normally. Though I'm guessing the switch has proven to be intermittent in the headlight position once warmed up. Can't see any other reason you would do this.
I've removed it for now (not least because the gauge of wire isn't even close to being up to the job) and will investigate further at a future date.
I had also wanted to have a look at seeing if I could sort the handbrake switch as currently the brake warning light on the dash only comes on via the float switch on the reservoir, and it should also work when the handbrake is on. I know the lamp itself does work as I've tested it.
However I failed at the first hurdle - how to get into the centre console far enough to find the switch. I'll need to consult a manual to confirm where the fixings are so I can get it apart without breaking any bits of brittle, near 50 year old plastic.
Current fleet:
Zelandeth
x 1593
There's a local classic car gathering tomorrow (Sunday 31st) afternoon at the Beefeater opposite the XScape in Central MK tomorrow from 1500. My intention is to be there in something. Most likely the Trabant as the Rover is still covered in moss to an embarrassing extent to be seen in public beyond being passed on the road. Granted, the Trabant being 3/4 polished does look a bit silly too.
If anyone on here is likely to be there, feel free to say hello.
Total car news for today consisted of putting the Renault's battery on to charge and chucking a piece of fuel line to replace the bit that's rotted off so it can be started up for the first time in far too blasted long tomorrow. Along with the Rover she also really needs a wash as the moss is taking hold.
A friend has very kindly given me another mechanical fuel pump for the Rover. It does need a full service and is missing a couple of bits, but with the remains of my old one should be sufficient to make one good unit. I'm inclined to give it another chance as I now know I was originally facing a losing battle with no return line - plus my original pump was obviously just cursed and wanted to die! I've ordered a replacement lid/pump for the washer bottle along with a fuel pump service kit - the whole bottle is annoyingly expensive, so I'll be trying to repair the crack in my one before giving in and replacing it. It's usable as it is in a pinch, you just can't fill it more than about 1/3 of the way.
I really need to get started on putting a web page together for the Trabant as well I think. It's always such a chore trying to catch up with everything done if I leave it too long!
Current fleet:
