1998 106 1.1 Zest 3 Idling Issues
Robc76
Unread post by Robc76 »
Good afternoon,
I have a 1998 106 1.1 Zest 3 which, I believe, has the TU1M(HDZ) engine with the Bosch fuel injection. A couple of months ago two issues manifested:
1) The engine misfired when accelerating
2) The idle speed would drop to 500rpm or the engine would stall completely.
Issue #1 was fixed with new spark plugs and HT leads.
Issue #2 is intermittent. Sometimes the engine will idle fine, sometimes idle at 500rpm and sometimes cut out entirely. Often, mostly when the engine is cold, the check engine light illuminates for a few seconds. Often the engine will idle fine when warming up then the revs will drop, or the engine will cut out entirely when at full operating temperature. As the car is pre-ODB-II I cannot read the codes myself so I took it to my local garage. They saw codes for coils, throttle position sensor and idle control valve which they subsequently cleared. They also spotted a damaged pin on the throttle position sensor connector plug which they repaired. After this they took the car on a test drive then let it idle for some time. Once again, the low idle returned and they found error codes for coils, throttle position sensor and idle control valve. They suspect an ECU or wiring loom fault.
So that's the summary. My questions to this forum are:
1) Is it likely the ECU or wiring loom has a fault somewhere?
2) The car has had a new coil pack in the last year or so, before my ownership.
3) The Bosch throttle body does not appear to have a throttle position sensor that looks anything like those for sale online. Is this throttle body one that needs to be replaced in its entirety just to replace that sensor?
4) Am I even looking in the right place for the throttle position sensor (right had side of the throttle body as you look down on it)?
5) The idle control valve also does not look like anything available online although it does look like it can be removed easily. Can someone point me toward a suitable replacement?
What else can I do to trace this issue? I bought this car for my son to learn to drive in and this issue is making it difficult for him. Once the car is moving it normally runs perfectly. I say normally because yesterday it would cough and kangaroo when accelerating in 1st, 2nd &3rd between 2,500 - 3,000 rpm. This is a new behaviour and I am unsure of this is a symptom of the existing issue or something entirely new.
Any help or advice would be very welcome. If I can provide more information please just ask.
Regards
RobC
Oldpug
x 93
Re: 1998 106 1.1 Zest 3 Idling Issues
Unread post by Oldpug »
https://uk.vicedeal.com/products/idle-c ... bAEALw_wcB
Does your idle control valve look like this?
x 8093
Does your car have the Bosch single-point injection?
If so, the symptoms point to a defective throttle position sensor pot. I've had this issue twice and both times successfully resolved it by very carefully dismantling the throttle pot, gently cleaning it with a solvens such as IPA and reassembling it.
The throttle pot is very much part of the throttle body is not available as a separate replacement part.
I cannot emphasise how delicate the cleaning job is. It is all too easy to damage it beyond repair. Also, the assembly is held together with Security Torx screws and heavily Loctited. So much so, it's possible to shear off the screws. Bosch really don't want you going into the pot!
Robc76
@Oldpug, my idle control valve looks much different. It appears to be a threaded rod that is actuated by a sprocket inside the valve housing. I have seen it move in an out from time to time.
@CitroJim, I do have the Bosch fuel injection and, I believe, it is the single point version. Do you have, or can you point me toward, a diagram, or photos, of the throttle pot and it's relative location on the throttle body? I'm not familiar with the term so I'm not 100% sure to what you are referring. I guess it is on the right side of the throttle body as you look down on it (with the air intake removed) which appears to have the throttle butterfly spindle connected. Is that right?
Regards
RobC
x 8093
Rob, this is the best I can do with a photo of the throttle pot and it's location on the throttle body...
Have a look and it'll be found on the right-hand side as you look at the engine from the front. It has a big electrical connector plugged into it...
The job can be done in-situ with care but do lay plenty of clean rags around just in case any screws try to make a bid for freedom.
Hope that helps a bit. I no longer have a car with an injected TU engine else I'd go and take more photos.
Oldpug
x 93
If you have mono injection forget my post, its for multi injection.
I would follow citrojim`s advice, mind you as jim has admitted, stripping the unit right down can be precarious. Why not first try a "basic" clean with special intake cleaner, all multi plugs checked and cleaned, that sort of thing.
If you could find an old school Peugeot Tech` with the old Peugeot Diag 2000 tool, who could clear the codes and reset the ECU that may help as well.
Robc76
Thank you.
For now, I think I will get some carb cleaner to see if a gentle clean of the throttle body and ancillaries will make any difference.
Thinking further ahead, I wonder if anyone has a Bosch throttle body complete with idle control valve and throttle position sensor for sale?
Regards
RobC
Oldpug
x 93
The best guy to try is Dean Hunter, www.peugeotparts.co.uk. I’ve used him many times, good service, can mail it.
He is also a Peugeot boffin and could give you some tips.
Robc76
Quick update: 10 minutes work with a toothbrush and half a tin of carb cleaner seems to have improved matters somewhat. The car is still not idling 100% but it has been much better these last couple of days. I thought the inside of the throttle body was painted black but it is just covered in old petrol residue. I may clean it some more to get it as clean as it can be (without completely dismantling it).
Regards
RobC
x 8093
That's good to hear Rob :D
Robc76
Update:
I'm slowly homing in on the idling issue. I have replaced the damaged loom connector for the TPS but that did not help matters at all. I managed to source a used throttle body which came complete with TPS and Idle Control Stepper Motor. I swapped out the stepper motor and this has improved things but it is still not 100%. There is still the occasional dip in idle revs and it did cut out once the other day. I still think the TPS is acting up; when the car is idling (usually when cold) the engine light comes on for a few seconds. If I press the throttle pedal slightly, the light goes out immediately. However, before I swap out the throttle body, I want to ask the forum if there is supposed to be a gasket fitted between it and its mounting bracket. The Haynes manual suggests there ought to be and I remember seeing an imprint of what looked to be a gasket when I lifted the throttle body for cleaning. So, should there be a gasket? If so, can someone please point me to where I can purchase one? If it comes to it, I can get some gasket paper and make on if they're no longer easily available.
Regards
RobC
x 8093
I can't be 100% sure Rob but I'd think there would be a gasket.
It's not going to be a very complex one and making one from a sheet of gasket paper should be absolutely fine...
Robc76
Thank you. That's my thought too. I do wonder if thickness matters though. Any thoughts on that? Maybe that only matters for carburettors.
Regards
RobC
x 8093
Robc76 wrote: 29 Apr 2024, 10:08 Thank you. That's my thought too. I do wonder if thickness matters though. Any thoughts on that? Maybe that only matters for carburettors.
Regards
RobC
No, I don't think it will Rob. I've used a cornflake packet for gasket material in the past with no issues...
Robc76
Update:
For the last two months my 106 has been happily running on its replacement throttle body. Prior to fitting it, I swapped the idle control motors between the old and "new" throttle bodies and it did not fix my issue. That leaves three possible causes: 1) Throttle Position Sensor, 2) Gasket or 3) Injector. As I wanted to get the car running well as soon as possible, I simply fitted the "new" unit and the problems went away immediately. Given the symptoms, I believe the issue was the Throttle Position Sensor although the old gasket didn't look to be in good condition. For a short time, the engine management light would still illuminate when idling but after a few weeks/few hundred miles, this ceased.
So, now the idling/stalling issue has been fixed, it has meant my son has learned to trust the car and has had many driving lessons in it. He is now ready for his test.
Thank you to everyone who helped get me to this resolution.
Regards
RobC
