C4 Grand Picasso 7 2.0 petrol LH dipped beam not working.
BigT
Unread post by BigT »
I’m a new member, so please forgive me if I make any etiquette mistakes. The car is showing a “LH dipped beam fault” but it’s not the bulb or fuse. When testing with a voltmeter and both LH and RH dipped beam fuses removed. I’m getting a strange reading of approx 7.5 v on the output side of the LH fuse holder and zero on the RH as a comparison. Would anyone be able to help with suggestions or a wiring diagram.
x 6955
Re: C4 Grand Picasso 7 2.0 petrol LH dipped beam not working.
Pop your VIN up as I need this for a diagram. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
BigT
GiveMeABreak wrote: 17 Mar 2024, 19:47 Pop your VIN up as I need this for a diagram. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks in advance.
Big T
PaulC5
x 669
Unread post by PaulC5 »
The vin may not be right, there should be a number after the VF and then it will also be masked from public view.
x 6955
I already corrected your VIN, so removed the superfluous post.
So on this there are separate fuses for both the Front Dipped and Main Beam lamps in the engine compartment Fuse box.
F16 (10A) is the Front Left Hand Main Beam Lamp Fuse
F17 (15A) is the Front Left Dipped Beam Lamp Fuse
So have you checked the correct ones?
x 6955
So these are the 2 fuses - have you checked them?
BigT
GiveMeABreak wrote: 22 Mar 2024, 23:48 So on this there are separate fuses for both the Front Dipped and Main Beam lamps in the engine compartment Fuse box.
Hi Marc
I have checked the correct fuses but when testing with a voltmeter with both LH and RH dipped beam fuses removed. I’m getting a strange reading of approx 7.5 v on the output side of the LH fuse holder and zero on the RH, which is correct, as a comparison.
BigT
Reason: Fixed Quote
x 6955
It may be that there's an issue with the BSM (Engine Fuse Box) internally.
There are 2 wiring possibilities for this vehicle, so I'll put both up. This can happen where there is a slight change / slight facelift.
With the exception of the wiring codes, most of the component codes are indexed here:
PSA Electrical Diagrams - Wiring & Symbols Codes Index
To give you a start 2610 is the left hand Headlamp.
PSF1 is the engine fusebox
BigT
Many thanks. This is a great help.
CroTech9
Unread post by CroTech9 »
BigT wrote: 24 Mar 2024, 21:33 Many thanks. This is a great help.
Hi, BigT
I am experiencing the same issue. Have you fixed yours? If so, would you mind telling me what was the root cause?
Thanks!
CroTech9
I have fixed it. RH dipped beam bulb died, replacing it did not fix the problem. Then after BSI reset, car turned on and the lights came back.
