dave101ua
Hello Marc!
Please number for this part
QUERLENKER VL LEMFORDER (TRIANGLE)
Google translate says it is : WISHBONE ARM
I need it for the front left wheel
Thank you!
Thank you!
- x 1485
Assuming for your Vin ending 172:
Left is 9846329580, priced at £245.54 in the UK. Note it appears to come without the ball joint (9803434080 @ £78.32) - and which comes without new nuts (3 off 9675784480 @ £1.67 and 1 off 5132A8 @ £4.88).
These are are a bit of a pain to replace, you have to remove the subframe extensions, which needs the front bumper off....
danlat1415
- x 24
Please could you let me know the part numbers for my front and rear brake discs?
Would my VIN tell you the exact ones?
Or would I still need to measure them to double check?
- x 6955
Front Discs
(1) Front Discs, part: 1647867480, £164.29
Rear Discs
(1) Rear Discs
OEM Original, part: 1609582880, £172.69
Cheaper Discs, part: 1687772580, £96.86
Rear Discs
(1) Rear Discs
Yewboy69
- x 3
I am looking for the part number for the female crimp on terminals that go into the brown 53 pin plug that plugs into the engine ecu. Pins 1 and 2. (To repair the plug)
2012 207 1.4 vti
Vin VF3**************[VIN obfuscated, can be read by forum staff]
I hope this makes sense!
2012 207 1.4 vti
- x 1485
I can't easily see that these are available separately. A trip to your local scrapyard perhaps...!
- x 6955
I've checked the electrical repair spares for suitable connections, but there aren't any for this type of connection, so as Richard says, possibly a scrappy or a new main engine harness at a mere £2600Yewboy69 wrote: 09 Mar 2024, 22:17 I am looking for the part number for the female crimp on terminals that go into the brown 53 pin plug that plugs into the engine ecu. Pins 1 and 2. (To repair the plug)
2012 207 1.4 vti
dylan26__
- x 22
Can I get the steering rack part number for VF7**************[VIN obfuscated, can be read by forum staff] please
- x 1485
New 1610768680 @ £2023.25 or Exchange 1674119680 @ £2195.93
£300 surcharge on each for return of the old item.
Note your car has an outstanding recall, but I can't see what it's for.
- x 6955
@dylan26__:RichardW wrote: 11 Mar 2024, 09:29 Note your car has an outstanding recall, but I can't see what it's for.
It's for updating the Engine Management Software for the DS3 'Racing', reference NLB. Ring your dealer and get it booked in for the update, it will be free of charge. Note in the Steering rack figures above, it does seem that a brand new one is actually cheaper than a reconditioned exchange one in this case.
nomad123
- x 5
Hello!
I need injector copper seal part number.
Citroen C5 X7 2.0hdi 103kw
Thank you.
Thank you.
- x 6955
@Nomad: Please check your Private Messages
nomad123
- x 5
- x 6955
(9) Injector Seal, part: 198177 (No longer available from Citroen), £4.40
(10) Injector Protector, part: 1982F1, £4.46
perrye
- (Donor 2026)
- x 10
Hi!
I'm looking for springs and shocks both front and rear
VIN VF3**************[VIN obfuscated, can be read by forum staff]
