dave101ua
Unread post by dave101ua »
Hello Marc!
Please number for this part
QUERLENKER VL LEMFORDER (TRIANGLE)
Google translate says it is : WISHBONE ARM
I need it for the front left wheel
Thank you!
x 1496
Assuming for your Vin ending 172:
Left is 9846329580, priced at £245.54 in the UK. Note it appears to come without the ball joint (9803434080 @ £78.32) - and which comes without new nuts (3 off 9675784480 @ £1.67 and 1 off 5132A8 @ £4.88).
These are are a bit of a pain to replace, you have to remove the subframe extensions, which needs the front bumper off....
danlat1415
x 24
Unread post by danlat1415 »
Please could you let me know the part numbers for my front and rear brake discs?
Would my VIN tell you the exact ones?
Or would I still need to measure them to double check?
x 6947
Front Discs
(1) Front Discs, part: 1647867480, £164.29
Rear Discs
(1) Rear Discs
OEM Original, part: 1609582880, £172.69
Cheaper Discs, part: 1687772580, £96.86
Yewboy69
x 3
Unread post by Yewboy69 »
I am looking for the part number for the female crimp on terminals that go into the brown 53 pin plug that plugs into the engine ecu. Pins 1 and 2. (To repair the plug)
2012 207 1.4 vti
Vin VF3**************[VIN obfuscated, can be read by forum staff]
I hope this makes sense!
x 1496
I can't easily see that these are available separately. A trip to your local scrapyard perhaps...!
x 6947
Yewboy69 wrote: 09 Mar 2024, 22:17 I am looking for the part number for the female crimp on terminals that go into the brown 53 pin plug that plugs into the engine ecu. Pins 1 and 2. (To repair the plug)
2012 207 1.4 vti
I've checked the electrical repair spares for suitable connections, but there aren't any for this type of connection, so as Richard says, possibly a scrappy or a new main engine harness at a mere £2600 :shock:
dylan26__
x 22
Unread post by dylan26__ »
Can I get the steering rack part number for VF7**************[VIN obfuscated, can be read by forum staff] please 🫡😊
x 1496
New 1610768680 @ £2023.25 or Exchange 1674119680 @ £2195.93 :? £300 surcharge on each for return of the old item.
Note your car has an outstanding recall, but I can't see what it's for.
x 6947
RichardW wrote: 11 Mar 2024, 09:29 Note your car has an outstanding recall, but I can't see what it's for.
@dylan26__:
It's for updating the Engine Management Software for the DS3 'Racing', reference NLB. Ring your dealer and get it booked in for the update, it will be free of charge. Note in the Steering rack figures above, it does seem that a brand new one is actually cheaper than a reconditioned exchange one in this case.
nomad123
x 7
Unread post by nomad123 »
Hello!
I need injector copper seal part number.
Citroen C5 X7 2.0hdi 103kw
Thank you.
x 6947
@Nomad: Please check your Private Messages
nomad123
x 7
I did.
x 6947
(9) Injector Seal, part: 198177 (No longer available from Citroen), £4.40
(10) Injector Protector, part: 1982F1, £4.46
perrye
(Donor 2026)
x 10
Unread post by perrye »
Hi!
I'm looking for springs and shocks both front and rear
VIN VF3**************[VIN obfuscated, can be read by forum staff]
