[SOLVED] Help with P0611 error
naicul
Re: Help with P0611 error
Unread post by naicul »
Nemo26 wrote: 16 Nov 2017, 19:58 Finally was able to solve m issue, here is solution
Hi there,
Some years later I get the same error as you did:
P1671 Cruise control - Information incoherent
P1607 Vehicle speed limitation - Information incoherent
P0611 Injectors - Fault : resetting of the injectors
P1471 EGR valve - Open circuit
Can you post again what was your solution?
I can't see it here anymore.
cantorgabriel
Re: [SOLVED] Help with P0611 error
Unread post by cantorgabriel »
x 6955
The OP used an external hosting site that no longer exists which is why you can't see the file. Another reason why we encourage members to upload their images directly to the Forum to prevent this happening in the future.
Theson
Unread post by Theson »
Hello , I am struggeking with this issue for months. I’ve changed the knock sensor and reprogrammed all 4 injectors and the error is still showing up
sanderson18888
Unread post by sanderson18888 »
Did you find the cause of fault and solution
sanderson18888
Nemo26 wrote: 17 Nov 2017, 15:59 None, accelerometar (knock sensor) was deffect, on osciloscope slow response. After replacing part, procedure for re-learnig pilot injection must be followed. This is described in document I have post earlier.
Are you still active as I have the same issue and need help
sanderson18888
naicul wrote: 03 Nov 2020, 21:13
Hi there,
Did you get this fixed as it’s the same on mine
Mrkerem
Unread post by Mrkerem »
Hello everyone. Not to open a new topic, I hope I can follow up here and find a solution. I hope someone will see this post. A few days ago I bought a Peugeot 508 2.2HDI 2012. And I noticed a "knocking" sound in the back of the car when idling. If I step on the gas for "1mm", the knocking stops and nothing is heard while driving. Otherwise, the car drives fine, except that it consumes a little more fuel. I connect it to the DELPHI diagnostics and it says error P0611. I see here that the detonation sensor is mentioned, but I don't think my car has it. If I'm wrong, someone correct me. Then I looked at the cables at the ECU and saw that some cables were cut. I'm attaching a picture. I don't know where the other end is, and you think that could be a problem. I am also attaching a picture of the injector at rest. Any help would be great. And excuse my bad English.
PaulC5
x 669
Unread post by PaulC5 »
Have you checked if the exhaust brackets are in good condition and not rusted off anywhere ?
Mrkerem
PaulC5 wrote: 21 Feb 2025, 21:45 Have you checked if the exhaust brackets are in good condition and not rusted off anywhere ?
Knocking was the motor carrier. But it still remains p0611. Today's injector correction is like this.
