[SOLVED] Help with P0611 error
Nemo26
x 4
Unread post by Nemo26 »
I receantly found this code stored in my ecu, and it's impossible to erase. It's about injector correction. Now, before i start to dissasamble everything, I'm interested did somebody have had experience with this failure. Car works normaly, i didnt noticed something different. Codes are pulled out with diagbox, and the car is c5 x7 2.0. Hdi 140 hp fap.
x 6946
Re: Help with P0611 error
" Electronic housing Fuel Injector - performance problem"
These are the possible causes I've looked up:
Faulty Fuel Injector Control Module
Fuel Injector Control Module harness is open or shorted
Fuel Injector Control Module circuit poor electrical connection
Have the injectors been changed lately?
Nemo26
x 4
No, i didn' t change injectors. Where did you found possible causes? Is it posible to search service box for code description? I didn't looked up electronic injection wiring, is it controled by ecu, or there is another modul?
x 6946
I've checked some info and researched it a bit - looking at the P0611, this is listed as Permanent Fault: The engine has not encountered the conditions for resetting the the injector idle time (high rail pressure) - Other...
I can't help further with this personally, but has been associated with lost injector codes. Citroen have a procedure for testing this - but I don't have this. Sometimes this will come on with a service light and possibly another fault code.
It is certainly something I would get them to do as one outcome is the car going into 'Limp Home Mode' - with the engine put into degrade mode to protect it.
Nemo26
x 4
Thanks, i'll try to input injector codes again. Weird thing is that everything is normal and no mil light is activated.
x 6946
Just be aware that there can be many reasons why this code may exhibit - I would be reluctant to change anything until you are sure this is the cause. If you haven't changed the injectors, then I suspect this will not be the cause. If the injectors are reading the correct codes in Diagbox or are not showing any odd codes then I would leave this. It is not getting some information from somewhere and that is the problem. I suspect that the main dealer will be able to run additional tests from their server that may not be available in the clones. It might be worth paying for them to do a full diagnostic first before you start changing anything though.
Nemo26
x 4
I suspect knock sensor is deffect. Still waiting osciloscope to confirm this. One more thing. I receantly by accident reset fap filter counter. Now in diagbox there is procedure to input aditive soot value in grams. This value must be obtained from service box, and I'm unable to find it.
x 6946
You shouldn't need to bother with that - normally topping up the additive and resetting the additive counter is all you need to do - in the Injection ECU - but if you have changed any other settings, then this may be triggering the error as it is in the same ECU.
Nemo26
x 4
After testing knock sensor with osciloscope high percentage of interruptions in signal. New sensor ordered, problem solved.
x 6946
Great, thanks for the update, pleased that cured the problem.
Nemo26
x 4
Bad news, today same code again. Does anybody here have acces to psa intranet to check aftersale description of code?
x 6946
That code is all I can find that I posted previously. Sorry to hear it's back.
Nemo26
x 4
Finally was able to solve m issue, here is solution
Reason: Domain no longer Exists for Image - Please ensure you upload images directly to the Forum instead!
x 1941
Unread post by Paul-R »
Which one of the areas to inspect turned out to be the fault?
Nemo26
x 4
None, accelerometar (knock sensor) was deffect, on osciloscope slow response. After replacing part, procedure for re-learnig pilot injection must be followed. This is described in document I have post earlier.
