evening everyone!!!
i am hoping someone can point me in right direction, i have a ds3 2015 1.6hdi couple of days ago i had heater resistor go so managed to get this going again at the same time i had a number plate light to replace as it was blown, i replaced this started veh checked light it was not working so i took bulb out again and a bit of tin foil dropped out, it appears to me the previous owner had replaced the blown bulb and wedged abit of foil in there as the bulb didnt fit snug by the looks of things, im guessing this has shorted something as now i have esp/asr fault with traction control light on. the number plate light is working and everything else seems to work ok. i have put new battery on car as the one that was on there was 10yrs old and my stop start has not worked for couple of years and still doesnt. i have checked fuses and can not see any blown. could this of spiked the alternator.
esp/asr fault
- x 6955
Re: esp/asr fault
You need to have it diagnosed and then get us the fault codes to assist - it may be totally unrelated to the light issue.
cooper1973
Re: esp/asr fault
Oh sorry was ment to add these fault codes c1644 , c1384 , p1536 I went out this evening and stop start is working now which has not worked for couple of years.GiveMeABreak wrote: 01 Mar 2024, 21:08 You need to have it diagnosed and then get us the fault codes to assist - it may be totally unrelated to the light issue.
- x 6955
Re: esp/asr fault
...and your VIN so I can relate the codes to the exact vehicle.
- x 6955
Re: esp/asr fault
This is the only one I have until I get the VIN:
| Fault Code: | C1384 |
| Description of Fault: | Stop lamps information fault. Coherence fault. |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P1536 |
| Description of Fault: | Measurement of the brake pedal position : Lack of coherence between the two brake sensors detected on deceleration. Lack of coherence between the main brake and the secondary brake during sharp deceleration for 500 ms. |
| Symptoms: |
| Suspect Areas: |
cooper1973
Re: esp/asr fault
vin VF7**************[VIN obfuscated, can be read by forum staff]
- x 6955
Re: esp/asr fault
I've updated my previous post to reflect P1536, but C1644 is not coming up as a valid code, so I would re-check that. In both cases though, the common denominator is the brake switch, which is the only component that gets physically used, so is prone to failure at some point. I suggest you start there first and get that replaced. Make sure you get the exact correct part.
cooper1973
Re: esp/asr fault
c1644 from what I have read in another post is week battery which has now been replaced. I removed brake light switch and adjusted it and the warning has not come back as yet so hoping this may of been the issue I also cleaned the 2 5amp fuses on battery module as one was corroded not sure what these 2 are for but after doing this stop start has been working again.GiveMeABreak wrote: 02 Mar 2024, 09:17 I've updated my previous post to reflect P1536, but C1644 is not coming up as a valid code, so I would re-check that. In both cases though, the common denominator is the brake switch, which is the only component that gets physically used, so is prone to failure at some point. I suggest you start there first and get that replaced. Make sure you get the exact correct part.
- x 6955
Re: esp/asr fault
Great, a cheap fix!
cooper1973
Re: esp/asr fault
fingers crossed as I have been out in car today and fault didn't show up
