Hi I’m wondering if anyone can help. I have a Citroen berlingo 1.6 HDI van 13 plate. Whenever I accelerate hard or put my foot down in a high gear the engine either shuts off with the red stop light or it jolts and the engine light comes on and the triangle light. The fan then stays on when I turn the engine off along with the triangle light.
I’ve had a new fuel filter fitted twice and both times the van has run perfect for a week with much more power and smoother to drive then the same things starts happening.
I took it to a garage and these were the fault codes.
Citroen berlingo 1.6 HDI engine shutting off
- x 6957
Re: Citroen berlingo 1.6 HDI engine shutting off
So her are the main faults concerning the fuel system. So I'd focus on these first, but basically the fuel pressure in the rail is insufficient and this is despite the regulator fully open. So looks like a blockage in the fuel system before the fuel gets to the regulator or the regulator itself. Do you run the vehicle on 'fumes'? If so, gunge and diesel sludge will be a factor getting picked up; or the fuel filter has not been put back on correctly and the circuit primed properly are things I can suggest.
| Fault Code: | P0113 |
| Description of Fault: | Measurement of the air temperature at the air flow sensor: Short circuit to positive or open circuit: Temperature too low. Voltage higher than 4,9 V for more than 1 s |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0087 |
| Description of Fault: | Fuel circuit: The pressure measured in the injection rail is less than the setting. The pressure measured in the fuel high pressure common injection rail is lower than the reference value for 800 ms even though the electrovalve is open to the upper limit. |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0093 |
| Description of Fault: | Fuel system: Incoherence on the fuel pressure with the flow regulator jammed open. Excessive under-capacity of the injection system to provide the pressure for the flow in progress. The pressure measured in the fuel high pressure common injection rail is more than 250 bars lower than the reference value (For 800 ms). |
| Symptoms: |
| Suspect Areas: |
Nick1988
Thank you for taking the time to write such a detailed reply.
I did also have the fuel tank cleaned a few weeks ago and the guy said the diesel smelt really bad? Again the van drove perfect after that was done for about a week.
The garage also mentioned it’s a possibility it could be the injectors?
- x 6957
With that new info does it not seem a coincidence? There could be some dislodged muck that has got into the fuel system and causing a blockage somewhere.
Some treatment with a fuel cleaning additive for the next few tanks of fuel may help.
shtu
- x 78
Few things I can think of,
There may be a coarse\sock type fuel filter on the tank pickup. When the tank was cleaned, you would hope that they also cleaned the pickup.
The berlingo has an in-tank fuel pump. That may be going weak, so that could be checked.
What came out of the replacement fuel filters? If it was watery\milky, you are dealing with water contaminated fuel. Pull the filter and empty the contents into a clean jar. Check for any unexpected sediment in the filter.
Are the fuel lines clear and undamaged?
Sounds to me like the tank had accumulated some water, which then grows nasty moulds in, sometimes called "diesel bug". Is this van little-used, often left with little fuel in the tank? That's prime conditions for condensation in the tank.
Obviously this bunch would like you to buy their treatments, I'm not suggesitng that, but it gives an idea of what might be going on, https://www.fuel-guard.co.uk/road-vehic ... l-bug.html.
I'd go back to whoever cleaned the tank and complain it's still blocking filters every few hours.
That's a pointer towards diesel bug.Nick1988 wrote: 02 Mar 2024, 21:17 I did also have the fuel tank cleaned a few weeks ago and the guy said the diesel smelt really bad?
malc4
- x 3
Think i defo have diesel bug- a slimey residue on the fuel filter. (prolonged periods with a near empty tank?)
Low fuel pressure faults were P0087, P0093, P1199 i think. Measured fuel pressure falling behind instructed under load.
Have treated full tank with biocide and dry fuel treatment. Will wait for a few days until dead microbes settle at bottom of tank (in theory)
Then expect several fuel filter changes as the sludge is drawn through is one option, but i'd like to draw the sludge at the fuel filter with a pump (if i can determine the one from the tank- is it the one with the metal clip?).
Prino
Hi. Did you ever get to the bottom of this issue, as I have exactly the same problem
