Hey, I have a problem with my Peugeot 508 4Hybrid, 2012.
After replacing the right rear hub and levers, error P1ABB appeared, which I cannot clear, and associated errors P1ABE, P1ABF, U1318. I tried changing the gearbox position sensor - no change. Thanks in advance for your help!
Peugeot 508 RXH HYBRID 4 P1ABF
Hybridna
Re: Peugeot 508 RXH HYBRID 4 P1ABF
Hi i have fault codes only P1AC4 somebody maybe wiring diagram ECU to HCU peugeot 508 2011 hybrid?Thank you
Tatra-603T2
I have similar problems with my January 2013 508RXH, VIN VF3**************[VIN obfuscated, can be read by forum staff] engine number DYZC4019867 with getting on for 150,000 miles under her belt.
My drive belt tensioner started to get noisy and was jumping around and the fault was diagnosed by my local garage as the bearings in the hybrid generator. I had them replaced by the well-known advertiser on eBay and the unit was refitted by the garage at the beginning of May with a new belt and now it has a myriad of problems. They've re-set the belt counter and cleared umpteen fault codes but still the car plays up after a few hundred metres and then refuses to go into other modes than Auto. Sometimes it limps too and they say it's dropping the turbo. The power flow diagram shows power from the generator to the battery when the car's cold or after the isolation plug (?) on the top right of the inverter is removed and replaced - sometimes to clear the "STOP" message to even get the car to move. They don't have a Peugeot Planet 2000 (Lexia-3) but do have a pretty good diagnostic kit and they've even subscribed to a specialist service which has controlled it remotely. I've a very good relationship with them (see my list of cars!) and they have no problems with me helping them with work on my own cars and they've given me a list of codes they're "struggling with", as follows:-
P1B1B
P1AC4 (1AC4)
U12C6 (D266)
UO167 (C167)
Both they and the specialists they've consulted now suspect the inverter. I can get one from a scrapped car but they've been told that it can't be replaced by a second-hand one because of the immobiliser. The one I can get is from a DS5 so I don't know if there are differences even though the part number is the same.
Any help would be very much appreciated as the garage have had the car since late April and I'm desperate as my lady and I are due to go abroad in her soon.
P1B1B
P1AC4 (1AC4)
U12C6 (D266)
UO167 (C167)
- x 6963
Here are the descriptors, but in all cases the Hybrid ECU is a suspect.
| Fault Code: | U0167 |
| Description of Fault: | Intersystems CAN: Absence of response to the unlocking request. No response from the built-in systems interface following an unlocking request from the hybrid control ECU 1. Conditions of activation of the diagnostics The following conditions have to be met: - Ignition on - Indicator lamp READY lit |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | U12C6 |
| Description of Fault: | Hybrid CAN Control network: Length error or prohibited value of the frame from the hybrid management ECU 2. Description of the diagnostics: Communication fault between ECUs detected for 0,5 secs. Conditions of activation of the diagnostics The following conditions have to be met: - Ignition on - Indicator lamp READY lit |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P1AC4 |
| Description of Fault: | Drive train: Failure of the activation of the electromotor sub-assembly. Description of the diagnostics The electromotor sub-assembly is not activated after 2 s for a partial activation request or 3 s for a total activation request. Conditions of activation of the diagnostics - The following conditions have to be met: - Ignition on - Indicator lamp READY lit |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P1B1B |
| Description of Fault: | Hybrid control ECU 1: Internal fault. The fault appears after 2,5 seconds. Conditions of activation of the diagnostics The following conditions have to be met: - Ignition on - Indicator lamp READY lit |
| Symptoms: |
| Suspect Areas: |
Tatra-603T2
Many, many, many thanks.
The obvious questions now are:-
How has refitting the original generator caused all this? At first the faults only seemed to appear when the car began to warm up so could not bleeding the hybrid cooling system properly when first refitting the generator be the cause?
Can a second-hand hybrid control ECU be fitted and, if so, how is it done?
Can a DS5 hybrid control ECU be fitted to a 508RXH?
- x 6963
Unfortunately not. The DS5 has one or 2 similar components, but the ECUs are different. These have specialist requirements and training to work on, so I can't help with that, sorry.
vic678
Any luck yet on this ?Tatra-603T2 wrote: 21 Jun 2024, 14:01 Many, many, many thanks.
Davids1987
- New User
Hello, i have same problem with my car (2013 hybrid4 ds5)
We fix it the generator, and I have just the p1ac4 fault code.
How i can activate the the electromotor sub-assembly? I have Lexia diagnostic. Yesterday I try, but wrote me the message, i cant do it jet.
Thank you
Thank you
tiomavladimir
Hey, did u solve your problem? I just haven’t sameKristijonas wrote: 17 Sep 2023, 19:21 Hey,
VIN: VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
The diagnostics shows error P1ABE.
The issue is that the car sometimes suddenly jerks. This happens both when the car is in electric mode and in 4WD mode. For example, when you start moving from a traffic light, the jerk occurs, the diesel engine starts, and you continue driving as usual. Sometimes, when you're in electric mode, the jerk occurs, and the car feels like it's in neutral for about 2 seconds before returning to normal in electric mode. It's quite peculiar because on some days, it happens a few times, while on others, it occurs every time you're in electric mode. Has anyone else experienced this issue?
tiomavladimir
Hey do you reaolved your problem?thxAdizntk wrote: 31 Mar 2023, 17:05 Good evening everyone
I have issue with my hybrid system, the clutch on electric engine is not engaging so I have replaced the whole engine and diff with another working one but it’s still throwing this code P1ABF. I don’t know where else can I look so if someone can help me I would very appreciate that. Thanks
