Peugeot 508 RXH HYBRID 4 P1ABF
Adizntk
Good evening everyone
I have issue with my hybrid system, the clutch on electric engine is not engaging so I have replaced the whole engine and diff with another working one but it’s still throwing this code P1ABF. I don’t know where else can I look so if someone can help me I would very appreciate that. Thanks
Reason: Images corrected
- x 6950
Re: Peugeot 508 RXH HYBRID 4 P1ABF
I'll need the VIN first, (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff).
Adizntk
GiveMeABreak wrote: 31 Mar 2023, 19:03 I'll need the VIN first, (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff).
The vin is: VF3**************[VIN obfuscated, can be read by forum staff]
- x 6950
The fault is recorded in the Hybrid Control ECU (1)
This is what the fault means:
| Fault Code: | P1ABF |
| Description of Fault: | Motor: Absence of coupling. Failure to couple the reduction gear after 3 attempts. Conditions of activation of the diagnostics The following conditions have to be met: - Ignition on - Indicator lamp READY lit |
| Conditions for Fault to clear: | Issue 3 coupling requests (shifting gears) after repair. |
| Downgrade Modes whilst Fault is active: | Driving possible only in combustion mode. |
| Symptoms: |
| Suspect Areas: |
Adizntk
So I had the whole thing replaced sourced from donor car and I could see it working before, now I’m wondering what is the electric traction machine? I will scan the car tomorrow again and see if there are any other faults. Is there a procedure to calibrate the lot after replacement was done? I spoke to someone today who told me that this fault can also occur if the vacuum pump is not working properly but I don’t know if that’s true. Thanks
Reason: Removed Quote (no need to quote previous post)
Adizntk
Do you have the wiring diagram by any chance?
- x 6950
Here's the Traction System:
1919 : power electrical unit and control unit
6714 : - The transmission mode selector
7800 : ESP ECU
1920 : low temperature coolant pump
1917 : front electric machine
1918 : rear electric machine
6704 : hybrid rear reducer
1760 : battery HT+ battery status supervisor
1036 : converter power supply protection fuse
7800 : ESP ECU
Vytautas
Peugeot 508 2.0hdi hybrid 4 maybe someone can help me, I have such faults as U12C7, P1B70, P1AC4
noahkaral
Hey. Perhaps someone fixed the problem with P1ABF and has solution?
Vytautas
Hi please help I’m have problem with my Peugeot 508 rxh hybrid 4. When I’m start drive only electric motor, driving fine but when I’m drop acceleration and start charging battery rear wheels. throws errors
U0167
P1B70
PIAC4
U0167
P1B70
PIAC4
- x 6950
I'll need your VIN to double check (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff), but I suspect the following info is relevant:
So it probably needs some specialist investigation. The ECU on some models can be replaced (They are a little under £3k or a new battery itself with the ECU is about £6.5k).
Although the ECU
| Fault Code: | P1AC4 |
| Description of Fault: | Drive train : Failure of the activation of the electromotor sub-assembly. The electromotor sub-assembly is not activated after 2 s for a partial activation request or 3 s for a total activation request. The following conditions have to be met: - Ignition on - Indicator lamp READY lit |
| Conditions for Fault to clear: | 3 activations/deactivations of the electromotor sub-assembly. |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P1B70 |
| Description of Fault: | Resolver: Signal wrong or absent. Indicator lamp READY lit |
| Conditions for Fault to clear: | - |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | U0167 |
| Description of Fault: | Intersystems CAN: Absence of response to the unlocking request. No response from the built-in systems interface following an unlocking request from the hybrid control ECU 1. The following conditions have to be met - Ignition on - Indicator lamp READY lit |
| Symptoms: |
| Suspect Areas: |
Although the ECU
michaloko
- New User
Adizntk , did you fix your problem ? i have same error and same problem ,replaced the whole engine and diff with another one but still same error,i suspec the problem is hybrid control module but not shure ,coudl you share howe you fix your car?Adizntk wrote: 31 Mar 2023, 17:05 Good evening everyone
Kristijonas
- New User
Hey,
I have a problem with my Peugeot 508 4Hybrid, 2012.
The diagnostics shows error P1ABE.
The issue is that the car sometimes suddenly jerks. This happens both when the car is in electric mode and in 4WD mode. For example, when you start moving from a traffic light, the jerk occurs, the diesel engine starts, and you continue driving as usual. Sometimes, when you're in electric mode, the jerk occurs, and the car feels like it's in neutral for about 2 seconds before returning to normal in electric mode. It's quite peculiar because on some days, it happens a few times, while on others, it occurs every time you're in electric mode. Has anyone else experienced this issue?
- x 6950
| Fault Code: | P1ABE |
| Description of Fault: | Motor: Unwanted uncoupling. During a phase when the reduction gear is engaged (coupling successful), the "reduction gear status" is "disengaged". Conditions of activation of the diagnostics The following conditions have to be met: - Ignition on - Indicator lamp READY lit |
| Symptoms: |
| Suspect Areas: |
