Electrovalves on Xantia Activa
Rostami
Unread post by Rostami »
Hi to all,
The rear suspension of the Activa has two electrovalves near the RAM.
Does anybody know what they are for or how they work? Also, why 2 electrovalves?
Rostami
ActivaV6uk
Unread post by ActivaV6uk »
One is the normal HA system the seccond is the rear activa bridge valve (there is a front one too they let presure in and out of the 2 back bone pipes that are the hart of the activa system (any citroen sepecialists reading this I am looking for a job!!!)). I am going to write all this up at some point...
406 V6
Unread post by 406 V6 »
You SHOULD write a book on the Activa [:D]. I'll ask HRM Queen Elizabeth to make a dispatch for that purpose[;)]
Rostami
Thanks for the reply!
Just one more question: I was taking the LHM reservoir out the other day and noticed an aluminum box below it with about 5 high pressure lines connecting to it. Is this THE Activa control? Any more information about this black box?
Thanks,
Rostami.
ActivaV6uk
its the main security valve what the preasure comes to and from everything in the car.
there is another one buried in there which is the anti sink too...
Andy
Rostami
Andy,
The whole Activa is muc more complex than I dared imagine. Where can I get some documentation from? Does Citroen sell their technical manuals?
ActivaV6uk
A lot of it is from taking the car apart my self I actually have a whole Activa system sat in my shed waiting to go onto the V6 (you can tell how broke I am by this but the only reason I haven’t fitted it is because I need a £25 pipe that got damaged whiles being removed and I cant afford it :( ).
Although I have the Activa manuals they actually don’t show you how the system is really put together as they do the breakdown as if it was 3.5mm pipe with K connectors and alike in reality there are 2 6mm pipes that run front to back these each connect directly to the Activa rams. each pope has an Activa bridge block attached in line which is just an on and off electro valve with an link to the other back bone (6mm pipe) so the valve can either let pressure into a pipe from the other or make it so the pipe is self contained. the 6mm pipes are unusual in that they have connectors coming directly off them (this is the only Citroen pipe that i know to be like this) the one pipe has the main supply feed ( goes to the block you mentioned under the tank), damper (Balancing Sphere - front), reserve (Balancing sphere - rear), connector to the Activa role controller. The second pipe has just the connector from the other pipe via the 3.5mm output form the bridge and a connection to the Activa role controller. This may all sound hard but realistically its simple compared to HA which is also on the car!
Andy
ActivaV6uk
Rostami, if you need any help with the activa system p[ost the question on activanet and i will work through it with you with the citroen manuals and the experiance i have gained from playing. if we hit problems it would be nice to have common fixes on the website so all owners can get hold of info should they need it.
Andy
Rostami
Andy,
Thanks for your post.
I will post further questions on Activanet!
Rostami.
bernie
Unread post by bernie »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ActivaV6uk</i>
Andy
Is this the pipe(s) that I have Andy?
I've lost your address so email me and I'll send them on
ActivaV6uk
hi bernie its not but i do need that too (i will email you my address) the pipe i broke was the one that conects to the front activa ram and is a reinforced flexi hose (any one who has seen one will wonder how i broke it the answere is it was eather keep twisting the pipe untill the union was undone or lost the £150 pipe with the siezed nut on it :( so i managed to twist the pipe round enough times untill it gave up (25-30 times)
Andy
