Need help !! Citroen picasso C4.
Don't know what to look at now changed the maf sensor still the same . engine light on all the time . Code P0130 air flow sensor ] air quality measured too great ? I don't know if this as anything to do with it but the small pipe to the air box broke off so I glue a 6mm pipe in and connected back up . I'm at a loss now and need some help from all of you .
P0130 code need help please
Paulc5060
Reason: Moved to correct Forum
- x 1496
Re: P0130 code need help please
Check for a boost leak - look at the pipes downstream of the turbo to see if any are split, often given away by being oily. What engine is it?
Huskyxantia
- x 927
Restricted air , its that fix causing it.
Husky.
Paulc5060
Hi
Thanks for your help. It 1.6hdi adblue 2015 picasso
Funny you should say about the oil ! When I took the air box out it had oil all over it . The 2 pipes that come from the boost value have I think it's that have oil over them
How do I get to check them ? If it is what would be the part I need to look for . Thanks again
Paulc5060
Hi ,
Checked boost pipes for split all ok ! . Still got the same code P0103 00 . Anyone have any ideas so stuck .
Paul
Paul
Paulc5060
I also checked the voltage at the mass air flow socket it's reading 5v in 2 pins is that right
- x 1496
Can you see live data on your scan tool? What does it read engine off and at idle? Can you clear the code, if so what does it take to make it come back?
Paulc5060
On the scanner it said
Air flow sensor - Air measured quantity too great P0103 00 , just seen I've put the wrong code up
PaulC5
- x 704
Have a read of this long story but in the end it turned out to be a manifold air leak giving a greater air flow than expected. The poster tried lots of expensive fixes but in the end had a professional find and fix the fault https://speckog.wordpress.com/2019/10/2 ... ough-hell/
Paulc5060
Hi
Thanks for that but the car runs fine. It's just as soon as I start the car warning comes on ? Checked for air leaks nothing changed maf sensor still the same check the power from the plug 5v from 2 of the leads going in not sure if that's right need some help with this one and so far have been very great full just which I had put the right code up first.
Paulc5060
Hi ,
Morning there is no live data at the maf sensor I checked the voltage at the plug 5v at 2 wires . Not sure if that's right ?
Paulc5060
Car all sorted now thank god for that
- x 8428
That's good. What did you do to resolve this issue?
