Possible cause for concern ?
Huskyxantia
x 892
Unread post by Huskyxantia »
Found this ...
https://www.scoobynet.com/other-marques ... nsion.html
Do we need to worry ?
:-D
x 6955
Re: Possible cause for concern ?
No. it's an already known issue.
The work required a new safety spring cup to be fitted that would prevent spring damage. We had ours go on our old C3 and they were replaced. As far as I know this was only an issue on the C3.
Huskyxantia
x 892
I seem to recall last november at the mot for my 308cc the tester showing me the osf was different , no cup , long story short i did replace the front legs, all new now with cups on both .
:-D
x 6955
Good move, as they can cause a lot of damage if they go with missing or defective caps!
Stewart(oily)
x 35
Unread post by Stewart(oily) »
I find myself replacing a lot of springs these days, all makes and models, interestingly the majority of broken springs still have shiny paint on them, I also see rusty springs that look as if they have been on the seabed for ten years that just keep going. perhaps some drivers are more dilligent at pothole spotting?
x 6955
That'll be me - I'm more likely to have an oncoming collision from pot and drain hole avoidance!
x 8332
GiveMeABreak wrote: 13 Feb 2024, 10:05 No. it's an already known issue.
I take it not on the C3 Picasso. I checked for recalls yesterday and none advised...
Can you confirm Marc?
x 6955
Can you pop the VIN up for the C3 Pic Jim, I don't seem to have it.
x 1056
Unread post by wheeler »
The cups were fitted to C2, C3, Berlingo & Xsara Picasso as part of recalls. i have no idea how they determined which ones got recalled as not all got them fitted.
x 8332
GiveMeABreak wrote: 13 Feb 2024, 19:59 Can you pop the VIN up for the C3 Pic Jim, I don't seem to have it.
Thanks Marc, here it is: VF7**************[VIN obfuscated, can be read by forum staff]
x 6955
Nothing shown Jim. But then IIRC ours just went on the front driver's side one day when the car was being reversed - bang and that was it, collapsed at the front offside.
We had to get it replaced locally and towed on a flatbed, but luckily no peripheral damage.
x 8332
Thanks Marc 😊 I checked mine when I did my Pre-MoT and they all look fine 🙂 Hopefully that'll continue 🤞
Huskyxantia
x 892
Is it me or is the front suspension on the c3 picasso hard and loud ?
:-D
x 8332
Huskyxantia wrote: 17 Feb 2024, 20:02 Is it me or is the front suspension on the c3 picasso hard and loud ?
Stiff and jiggly on low-profile tyres like mine Husky but not loud or crashy... It's very conventional PSA stuff.
Huskyxantia
x 892
An investigation just now , ive got one side that looks like its all new and my side osf, looks pretty much very old. Front shock thump = worn shock spring is ok .
:-D
