- x 5672
Re: Citrojim's AX, Pixo, C3, Running and Cycling Tales
Durable Athlete On steroids?
- x 8368
mickthemaverick wrote: 13 Feb 2024, 14:48I used to be a pentathlete, football, cricket, golf, tenpin bowling and table tennis. (Ignoring the motorsports) But as you get older you gain extra things along the way which tend to reduce your abilities. The worst thing I have gained is a letter 'S'. :CitroJim wrote: 13 Feb 2024, 14:39
But we duathletes are made of tough stuff... Never has a bit if wind, rain and mud ever bothered us
- x 8368
Shhh, don't reveal all my secrets Steve
- x 5672
Pentathlete. Draws pentagons a hexagons are too much bother. Summons teddy bears in lieu of demons.
- x 8368
myglaren wrote: 13 Feb 2024, 15:02 Pentathlete. Draws pentagons a hexagons are too much bother. Summons teddy bears in lieu of demons.
- x 3306
Deccathlete. Somebody who repairs the Decca navigations systems while running alongside the vehicle in question.
- x 8368
Hell Razor5543 wrote: 13 Feb 2024, 15:38 Deccathlete. Somebody who repairs the Decca navigations systems while running alongside the vehicle in question.
- x 1067
No update....Is Jim off in Bluebell the tardis to get more 300 year old bearings or is he practicing his Trapeze routine with the sky hooks? NO.. he's off practicing the Luge and Skeleton incase we challenge him! You've heard of James Bond, well this is Jim Eastlasticatedman! Also known as 'Spandex Man'!!!!
Champion of Where's CitroJim
- x 8368
Rp0thejester wrote: 15 Feb 2024, 19:13 No update....Is Jim off in Bluebell the tardis to get more 300 year old bearings or is he practicing his Trapeze routine with the sky hooks? NO.. he's off practicing the Luge and Skeleton incase we challenge him! You've heard of James Bond, well this is Jim Eastlasticatedman! Also known as 'Spandex Man'!!!!
No, just very busy with various things that have conspired to keep me away from here for a while... Most of no great interest - mainly tedious admin work and hard training for the weekend's activities...
One activity I'm currently up to might be of some interest. It's automotive and electronic. I'll save that for later - likely next week now as this weekend is likely to be a fairly epic one
- x 8368
A little teaser of what's currently on my bench, undergoing a bit of surgery
Kudos to who can correctly name the car it was originally found in...
Skull
- (Donor 2026)
- x 379
I'm going to say BX it's only a guess because (I can't read the laptop screenCitroJim wrote: 16 Feb 2024, 15:13
Gary
Gary
- x 8086
I'll go a couple up from the BX and try an XM, there's a feeling of vague familiarity about it?
- x 8368
They may well have appeared in the BX Skull as it's a Citroen branded Clarion. This one is from the Series 1 XM so you are quite correct on this occasion Mick
The problem is the usual, radio OK but very low volume on tape. A common problem it seems. Conventional wisdom usually points to a problem with the Dolby module that does both the tape head preamp and noise reduction functions. I'm now doing all I can to confirm/eliminate that module as the cause. There are absolutely no details available for this module and no spares available. I have three of these radios, all with the same fundamental problem.
It is imperative this unit is made to work again so I may have to get creative
Michel
I don't recall fitting any Clarion units in BXs when I worked at BCC. One of the things us apprentices got dumped with was doing PDIs - fitting the optional stuff, stereos, number plates etcCitroJim wrote: 16 Feb 2024, 17:38 They may well have appeared in the BX Skull as it's a Citroen branded Clarion. This one is from the Series 1 XM so you are quite correct on this occasion Mick![]()
