Hi new to forum was wondering if i post my vin if any one can tell me which engine it has and also if this car would have a dual mass flywheel or not. I believe the engine is a DV6C 6 speed manual.
It is a 2011 C4 Picasso but i get conflicted info from using the reg or the vin to find parts.
Many thanks
1.6 HDI 8v or 16v
- x 1496
Re: 1.6 HDI 8v or 16v
Yes, post up the VIN (it will auto hide) and we can check. I would expect a 2011 to be a DV6C 8V, but if it was reg early in 2011, it could be a carry over car with the 16V engine. Either way it will have a DMF!
zaviero
Hi thanks for the reply.
Vin is VF7**************[VIN obfuscated, can be read by forum staff].
The reason I ask about dmf is I also have conflicting info that only the egs models have a dmf where as mine is 6 speed manual no egs that may not.
- x 1496
Hi
Service Box confirms DV6C 8V engine, and dual mass flywheel.
Note that SB also indicates a recall on it, which implies that if it's over 75k then they will replace the timing belt - so if it hasn't been done, then worth a chat with your local dealer to see if they will do it for free!
zaviero
ok thx for your help looks like its an expensive clutch and dmf replacement job then. I will look into the timing belt recall after that is sorted.
zaviero
Just one more thing if possible could you tell me which gearbox it shows this car as having. Many thanks
- x 1496
