Hi My son in-laws C3 2013 saloon is now difficult to engage the gears (gear stick very stiff) Worse when engine is cold and does improve when engine has warmed up. Any ideas would be appreciated please.
Mike
Gear Stick on C3 very stiff to engage gears
mikezener
- (Donor 2021)
- x 1485
Re: Gear Stick on C3 very stiff to engage gears
Is it hard to engage when the engine is not running? Has any work been done involving removing a driveshaft?
mikezener
- (Donor 2021)
Yes its still very stiff when cold and engine not running(first thing in morning) Theres been no work done re drive shafts. But there has been a cat fitted about 2 months ago by a well known chain and they had mentioned something about the gear box and gear stick.
quintet
- x 44
Have a look at the counter weight on top of the gearbox, they were prone for seizing up on the pivot point/bolt. It doesn't do a whole lot so i used to take it off & do away with it although i felt doing that does give a slightly wayward/looser feel to the gear change.
opinion may be divided on doing away with it but once these start playing up they certainly effect the gear change.
Music keeps me going.
mikezener
- (Donor 2021)
Thanks for the info, Found the counter weight and applied some lubricant to joints. Problem now solved
livewire101
same issue here.
where do you find the counter weight to lubricate it?
- x 1056
Huskyxantia
- x 898
Regarding No 6 how does the piece come off ? My first gear is stiff ok when warmed up , might try lubricate first. My car differs as it is citroen c3 picasso but i think might be similar
Husky.
- x 8343
I'd be interested to know this too as I'd never describe my Picasso as having a particularly slick shift...Huskyxantia wrote: 04 Feb 2024, 19:37 Regarding No 6 how does the piece come off ? My first gear is stiff ok when warmed up , might try lubricate first. My car differs as it is citroen c3 picasso but i think might be similar
Highlighted today when I took my AX for a drive
- x 1485
Doesn't look like that bit is fitted on the C3 Picasso
Huskyxantia
- x 898
Think i will investigate mine.
Husky.
