Hi everyone,
I recently bought a Peugeot 107 2 Tronic with a gearbox issue. I connected it to Peugeot planet and received the following error message:
"Automatic transmission control unit
Permanent fault. Clutch actuator motor signal."
I have already replaced the actuator with a known good one, as well as the gearbox relay and checked all the fuses. However, the same fault persists. Additionally, when I run a gearbox actuator test, it shows as successful but none of the actuators actually move.
I would greatly appreciate any assistance or advice you may have.
Thank you!
Peugeot 107 Trinic
- x 6956
Re: Peugeot 107 Trinic
We've deleted your 7 duplicate posts on this - reason being you have to wait until a moderator approves your post being a new user, so they wait in a queue until then. Repeating the post serves no purpose.
As for the fault codes, posting the actual codes along with the VIN is a good start.
- x 1056
What are the actual symptoms? does it drive at all? Select gears?
Does the clutch actuator need programmed on this car? has this been done. Good battery support can be critical on these when doing programming. Best to connect another car with jump leads.
Rods74
Thanks your reply.wheeler wrote: 04 Feb 2024, 15:53 What are the actual symptoms? does it drive at all? Select gears?
No, the car doesn't drive at all. It's unable to select gears. In the past, I have programmed many of these cars without any problems. However, when attempting to put the clutch actuator into service mode, it doesn't respond or move.
- x 5671
Image not working.
Rods74
