PSA NAC RCC Updates
- x 6955
Re: PSA NAC RCC Updates
Use the link for the Firmware update from the post above (viewtopic.php?p=787620#p787620), but do not use that Licence File - use this one which is for your specific vehicle:
Alanapone Licence File
quackyo
Any way you could make a license file for me to? (Berlingo 2021). Thanx in advance
VR7**************[VIN obfuscated, can be read by forum staff]
- x 6955
You don't need a licence file, as your vehicle has WiFi, so will authorise the update for you, as long as the engine is kept running for the update (which it should be anyway), so allow the vehicle to load all the modules before starting the update, to ensure the WiFi connection is made and you are doing this in an area that won't block reception. I've included it below in case you have issues, see other posts about how to use the licence file.
Firmware Version 44.07.05.22_NAC-r0
Quackyo Licence File
Map 15.0.0-r0
Map 15.0.0-r0
quackyo
Thank you very much! It worked perfectly
Larry Lamb
This is my first post, so hello everyone! I am having no luck downloading an update for our new Citroen E-Berlingo VR7**************[VIN obfuscated, can be read by forum staff] which I reset back to factory settings. Apparently the update we need is Touch Screen (6_0422_23.3137.1) but it will not download through the Citroen Update App. Thanks for any help in advance...
- x 6955
RCC Firmware Update version: 6_0422_23.3I37.1
Larry Lamb Licence File
After downloading the firmware, saving it to your PC, then extracting the firmware onto a FAT32 formatted USB key, you need to additionally create a folder in the route of the USB called 'licence' and copy the licence file into it.
seth999
Thanks, I tried 2 flashdisks 16gb, none of them worked, i have even tried creating different folders for the file you shared, Licence folder, License folder none of them worked. It's such a pain to update, maybe the license file is wrong for my car.
But anyways, my main problem was that android auto had stopped working some time ago. Today I tried a factory reset on the peugeot touchscreen and luckily android auto started to work again. I'll just reconfigure my settings now.
- x 6955
Licence file is correct - they are individual.
Upload a screen shot (use the full post editor to upload directly to the forum) of the USB showing all the content for me so I can determine if everything is there. I've supplied loads of these to others with the same type of system you have, so must be a local issue.
Jarous21
Any way you could make a license file for me to? (Berlingo 2021). Thanks in advance
- x 6955
Just the Licence or the firmware too?
Jarous21
Haven't you forgotten me? Thanks
Just the Licence. Thanks
SanJung
Hello, I live in Korea.
As I replaced broken RCC, the license key is no more valid.
I think new serial number is different from that of original RCC which registered in Peugeot server.
How can I fix this problem? Old dealers and new stellantis guys have no ideas.
If you give me a license file, will it work?
My Vin is
My Vin is
binogure
- New User
Hey,
I have the FAT32 US used Windows 11, but I miss the license file.
VIN: VR3**************[VIN obfuscated, can be read by forum staff]
Thank you
Cheers
Thank you
Cheers
NikolajPedersen
I'm having the same thing with my ë-Berlingo. Map update can download, touchscreen update refuses to.
My VIN is VR7**************[VIN obfuscated, can be read by forum staff] if you can help with licence and firmware.
Thanks a bunch, in advance.
- x 6955
The licence file is specific and unique to each vehicle.SanJung wrote: 31 Jan 2024, 07:47 Hello, I live in Korea.
My Vin is
The only way to get a working licence file is to provide me with the VIN of the vehicle that the RCC Head Unit came from.
