PSA NAC RCC Updates
iconstab
Re: PSA NAC RCC Updates
Thanks for your reply. It's the "... Application from the links below: For Windows:" and the "You download the files using the PC or MAC app" that are the problem, since there's no clue as to how to get the app with no link, etc.
Having said which, thanks for the offer, and here's my VIN : VR7**************[VIN obfuscated, can be read by forum staff]
Ian
Ian
- x 6956
Ok, so you have the RCC Colour Radio only, so just a Touchscreen update.
RCC Firmware 6_0422_23.3I37.1
License
1) Download to your PC. Use a programme like 7 ZIP freely available to extract the compressed Firmware file to a FAT32 Formatted USB of 16Gb minimum size. Do NOT copy the entire compressed file to the USB, only the extracted files and 7 ZIP should recreate the folders for you.
2) As you have no on board wifi, you need to manually add the licence file yourself, so create a folder on the USB root drive called “License” without the quotes and spelled exactly as I have written it. Copy the licence file (that has a 'key' extension into the License folder on the USB you just created.
3) Insert the USB into the vehicle with the engine already running. It will try to locate media files and give a warning - ignore it. After 10 seconds it should detect the Firmware and offer to update it for you.
4) Don't use you mobile phone during the update as if it is connected to the car it can interfere with the update if a call or message comes in. Don't press any buttons or fiddle with the controls during the update and keep the engine running.
License
iconstab
Thanks for these instructions. I have a 200 mile round trip to do tomorrow so will leave it till Wednesday. When you say "keep the engine running", you do know this is an electric Berlingo? I assume I settle for "keep the ignition on but in Park" !
Ian
Ian
- x 6956
Ha! I missed that, but with an electric one, you should be fine.
iconstab
Well, that was fun. Postponed the journey because of the weather, did the update.
Lesson learned: use a USB greater than 16GB, but not as big as 64GB, because exFAT format is not recognised - had to find an old camera card of 32GB that formatted to FAT32.
Upgrade worked, in the sense that the software and licence were read instantly (no warning, just Shall we do this?)
A very long 20 minutes - update hangs at 37%, then again for nearly 5 minutes at 54%.
End result - no change whatsoever that I can see. The same weird limited subset of apps from the phone via Android (Teams? really?) - and one - GBNews - that isn't on the phone.
ZapMap (I'm subscribed) loads a local map but still if I ask it to load a listed route it just twiddles its thumbs.
So, thanks for the help, but can't see any improvement!
Ian
Ian
- x 6956
The updates for the head unit are really for bug fixes and for phone bluetooth compatibility with newer phone models, so don't expect any new features
Zeph
I have the same problem. MyCitröen app says there is an update, but can't download. (6_0422_23.3I37.1)
I reached this forum looking for the exact number of the update. I tried downloading from the link that GiveMeABreak posted, formatted the usb device to FAT32 and extracted the files. Also copied the "key" file to the "License" folder.
But when i plug the usb to the car it says that the update is not valid.
I don't know if the license key is only for the VIN that Iconstab posted.
Can you confirm that the update file and license key are valid for my vehicle? VIN : VR7**************[VIN obfuscated, can be read by forum staff]
Thanks in advance!
Thanks in advance!
- x 6956
Zeph
Thanks for the quick reply and the license file!
I'll try to update and post results.
Thanks again!
Thanks again!
Pikachu93
PSA NAC RCC Updates
Hi all,
Just purchased the car (A 2019 Citroen C5 Aircross) and went to download the Update Tool after seeing it mentioned on the MyCitroen app. My computer refuses to download the file - it wont even entertain the idea. As soon as I click to download the Citroen Update Tool on the official website it just flashes up 'Failed'. I can't seem to find the file anywhere else. This is before I've even got to whether I have a USB drive big enough lying around!
Can I download the files 'over the air' using my phone data from inside the car? I'm not sure the wifi will reach (no driveway and someone is currently in our usual parking space in front of our house).
Can I instead use a external hard drive and does it need to be empty if I do?
Just not sure if I'm missing something wildly obvious or not!
Thanks,
J
Thanks,
J
- x 6956
Hi
There are mega issues at present all over the world with people not being able to download updates - it's a total disaster apparently.
You cannot update the vehicle any other way other than using a USB with the correct firmware or map update extracted.
First thing you need to do is provide me with your VIN so I can see if you have WiFi onboard, which will determine whether you need a licence file or not. Then I should be able to provide you with a direct link so you can download and extract the tar file to a USB that is formatted as FAT32.
You will have to bypass the update app as it's not downloading the files or working correctly at present.
Pikachu93
Hi @GiveMeABreak,
The VIN is VR7**************[VIN obfuscated, can be read by forum staff]
Thanks for the info
J
Thanks for the info
J
- x 6956
Ok, this is a combined Firmware and Map Update.
It's just under 24 Gb in size so you will need a 32Gb USB, formatted in FAT32 to install and ensure you have the engine running at all times during the update. If you have a connected smartphone, I suggest you switch it off to preven any calls coming in via Bluetooth during the update.
I have not included the licence files as you have WiFi on board, so another reason the vehicle must be kept running as well as to prevent it going into economy mode.
Combined Firmware and Map Update version 42.03.33.42_NAC-r0
Pikachu93
Awesome, thank you
Will give this a go later!
