06 C5 2.0 HDi fuel temperture sensor where is it?
Diabolical
Unread post by Diabolical »
OK I have come to conclusion that reason my C5 goes into limp on hardish acceleration is a faulty fuel temp sensor, managed to finally source one at not to bad a price, however i just cannot find it? on the car . Can anybody tell me where it is ?with a photo would be help numnuts here a bit.
Plus point has anybody on here changed one, i did a search and found nothing to help.
Cheers David
I can get round to posting a photo of where I think it should be
06 C5 2.0L HDi Exclusive Estate 20020k and rising. :-)
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
x 6950
Re: 06 C5 2.0 HDi fuel temperture sensor where is it?
I can't help with a photo as I sold my 2005 C5 2.0 HDi Exclusive - but if yours is the same engine, here's a diagram of the injection calculator sensor - if this is the sensor you are referring to it's number 10: :-D
Diabolical
Hi give me a break
it's this one
citroencx.co.uk
x 6950
Different engine then, but hopefully somebody will be able to get a pic for you. :)
KennyW
x 165
Unread post by KennyW »
Hi David,
I think it runs from the HP fuel pump on the side of the engine.
To find the hp fuel pump just follow the in line from the fuel filter.
I hope this helps as mine is a different engine model.
Kenny
C3 1.4 petrol (SWMBO)
Diabolical
Hi Kenny
i shall look when i have the time, though i do think the sensor has been removed because where i think it should be there"s a vacant blue plug?
I nearly bought X7 C5 160 recently but i had to stop myself, lovely motor.
citroencx.co.uk
KennyW
x 165
David,
You should have but everybody circumstances are different and these things tend to appear at the wrong time money wise :wink:
Kenny.
Frenchiemech28
Unread post by Frenchiemech28 »
P0181 p0183
These are known fault and there is a tech bulletin on Peugeot service box
Caused by faulty worn fuel pressure regulation valve / suction control valve on high pressure pump
Need to replace the pressure regulation valve and temp sensor on high pressure fuel pump together
This is on the RHR DW10BTED4 ENGINE
Often a metallic rattle knock can be heard on take off from fuel system and this is sign of the failure. Part numbers needed are
193339
1920NH
French car guru
darbuck
x 289
Unread post by darbuck »
I know that I am a bit late to the party but why do you have to change the temp sensor, does it cause the timing to retard
Darren
johnybr99
Unread post by johnybr99 »
Frenchiemech28 wrote: 12 Jan 2024, 04:25 P0181 p0183
193339
1920NH
French car guru
Hello, I think I'm facing this exact issue with my 2009. built 308. It's also with a 2.0HDi, 100KW. I managed to find the fuel pressure regulation valve. However, when I type in the part number for the temperature sensor, all I get are water temperature sensors with that same part number, 1920NH. Are those interchangeable in this case? They look the same as the one on the picture you provided, here's the link to the part. The site is in Serbian though:
https://www.prodajadelova.rs/senzor-tem ... log-as2156
I'd be super grateful if you could clear this up for me
darbuck
x 289
Yes they are the same part
Darren
