Have used the heat gun to reshape a good few, works well! Never strapped one to a wooden spoon though!
DIY Car Maintenance with function over finesse!!
- x 2347
Re: DIY Car Maintenance with function over finesse!!
Always save old tooth brushes, a quick go in the dishwasher gets them clean enough (for car jobs)
Did you put it back in the bathroom?mickthemaverick wrote: 11 Dec 2023, 19:59 No you are not Ryan, That's exactly what it is!! Works very well too![]()
- x 8403
I'm exclusively electric... I do have a few manual ones for those jobs where a toothbrush is just right. I've bought cheap ones in the past especially for cleaning jobs...MattBLancs wrote: 11 Dec 2023, 20:50 Always save old tooth brushes, a quick go in the dishwasher gets them clean enough (for car jobs)
Waste not, want notGibbo2286 wrote: 12 Dec 2023, 09:47Did you put it back in the bathroom?mickthemaverick wrote: 11 Dec 2023, 19:59 No you are not Ryan, That's exactly what it is!! Works very well too![]()
Sloppysod
- x 396
Never thought of that oneSteve Walsh wrote: 10 Dec 2023, 10:00 I always put PTFE on the nipple threads, It stops air being pulled in and also helps to stop nipple seizing in
I have splashed out and bought toilet brushes, great for cleaning the next size up apertures (didn't says holes as I'm trying to keep thread cleanMattBLancs wrote: 11 Dec 2023, 20:50 Always save old tooth brushes, a quick go in the dishwasher gets them clean enough (for car jobs)
Stu
- x 8126
No it was already in the cupboard under the sink for cleaning the bird table so it was returned there as it will still be ok for that!!Gibbo2286 wrote: 12 Dec 2023, 09:47Did you put it back in the bathroom?mickthemaverick wrote: 11 Dec 2023, 19:59 No you are not Ryan, That's exactly what it is!! Works very well too![]()
- x 2347
The electric brush heads are useful too, the Sonicare type things most useful (as no moving parts) but the rotary type things work ok for a quick scrub too.CitroJim wrote: 12 Dec 2023, 10:13 I'm exclusively electric... I do have a few manual ones for those jobs where a toothbrush is just right. I've bought cheap ones in the past especially for cleaning jobs...
I've an electric toothbrush head in each grease pot, good tool for it's application and fits in with the lid shut too!
Via the dishwasher again, eh!?
- x 8403
That's a good idea Matt, I'll start keeping them from now on...MattBLancs wrote: 12 Dec 2023, 19:37 I've an electric toothbrush head in each grease pot, good tool for it's application and fits in with the lid shut too!
- x 8126
I had a new toy arrive today, replacing my old version which had begun to decompose, so it will be interesting to try it out over the weekend!!
OnlineHell Razor5543
- x 3296
My Mum has one of these. We had to use it on Sapphire in August 2022. Took a while, but we emptied out around 200l from the engine bay!
- x 8126
Hopefully James my uses will be confined to 5-10 litres per time depending on whether its gearboxes, diffs or occasionally engines!
- x 3565
I wouldn't be without mine, however.......... I think it might be my pick-up truck........ one of the fleet has a handy feature in that it will trap the end of the suction hose in the bottom of the dipstick hole. The first time I got caught out was, not surprisingly, a little worrying
I tend to drop the sump plug on the truck these days which is why I don't get caught out any more
- x 8126
Coolant replacement update:
You may recall I recently flushed and refilled the MX3's cooling system, details here, and I have just returned from the first decent run since doing that work. After a 22 mile drive I am pleased to say that the engine is running sweetly with the temperature gauge reading just below where it used to. The heater is toasty to the point of having to turn it down and there are no signs of any leaks!! Job done!
- x 5673
Poking around with the Mazda 6 to see if there was a spare wheel or a can of gloop:-
Nice to see that there is a full sized spare, even looks like the other four. What was less pleasing was that it was partialy submerged. As was the jack, in a separate well. 'Well' being the operative word, although all was clearly not well
A previous owner has presumably had a roof rack that they have retined but not refitted the plugs for the attachment points, just put tape over which has leaked into the boot.
Aquavac clone to the rescue, may have to visit the dealer for replacement plugs.
Lots of niggles, some overcome, many remaining. Worked well on an eighty mile trip yesterday but son has had numerous problems including a flat battery, presumable due to one of the reading lights being left on. The interior lights are odd and seem to have a life of their own.
Can't set the clock, will have to disconnect the battery at midnight.
No music bar the radio which is also a very odd thing to set, so silence reigns. Did get radio 3 for a bit but that seems to have disappeared now. Aux input seems to be resisting.
Still need to work out the bluetooth. Son will never manage that as he won't talk to machines, it is all voice control. Perhaps his girlfriend will oblige.
New dashcam installed, seems OK for thirty quid (Amazon).
- x 8126
Good news on the spare Steve, pity about the gremlins. The interior lights on my last 6 were also oddly setup. Different delay times on the front and rear and different according to engine running or not I seem to remember. Good luck with them, sounds like you have an aerial issue too which may also be due to water ingress in the roof area!!
- x 8403
Great news Mick
Good to see a proper spare Steve but a shame about the well actually trying to be one... Hope no lasting damage has been done and caught in time...myglaren wrote: 07 Jan 2024, 14:20 Poking around with the Mazda 6 to see if there was a spare wheel or a can of gloop:-
