Doing mine last october i pinned 0000 , all works well since.MattBLancs wrote: 31 Dec 2023, 11:07 Is there a default code for Peugeot 308 stereo's Bluetooth connection?
(The phone suggested 0000 or 1234, will have a play later)
Will have to clear out the half a dozen previous owners phones from it too!
Huskyxantia
- x 927
Husky.
Huskyxantia
- x 927
Very impressive, when changing my sump & strainer last month
There's about 500ml left in the sump because of this inward design i belive who developed this sump had the blue print back to front, now making a point of using my small battery powered vacumme pump to suck out the rest at every oil change now. Well done for modding yours
Husky.
- x 2366
Huskyxantia wrote: 06 Jan 2024, 08:50 Very impressive, when changing my sump & strainer last month
Yes, I measured it too, just daft, isn't it!
The only thing that makes any sense to me is if the sump plug is recessed to reduce the risk of it being sheared off if the car was "grounded out" but if you are doing that much then the thin sheet steel of the sump itself isn't exactly armoured!
- x 2366
Will have another go at the Bluetooth soon, fingers crossed 0000 does the trick
- x 2366
This is a bit too much of a "it either works or it doesn't" approach for me!
I bought a second hand sump, modified it, then did a swap at next oil change. At least my method didn't have potential to leave me stranded!
I actually modified 3 sumps by this method (as had a 1.6 HDi C4 at the time too)
The third sump I used a normal socket rather than impact and the sharper edge instead punched rather cleanly through the sump instead!
As that was a spare / was going to sell it on eBay, that was the end of that!
- x 2366
Strangely the undertrays when searching for 7013EC look much shorter than the Peugeot diagram Marc kindly supplied
But the price is much more palatable!!
- x 2366
Coolant, am thinking a full change, flush then this:
Hexeal Red Antifreeze offers outstanding protection against corrosion, overheating and frost. Hexeal OAT is a 2 year Long Life Antifreeze with Organic Acid Technology corrosion protection. The exceptional thermlong-lifeity eliminates the risks of deposits particularly near the cylinder head, engine block, radiator, water pump and heat exchanger. Our Red Antifreeze is Nitrite, Amine, Phosphate (NAP free), Borate and Silicate free. It conforms to BS:6580 (2010), ASTM D3306, SAE J1034, ASTM D6210 , AFNOR NF R15601 (with the exception of reserve alkalinity).
Huskyxantia
- x 927
Dont forget theres already part undertray there below the rad & intercooler, as for slide hammer on sump oops look at my new massive drain hole
Husky.
Huskyxantia
- x 927
Very much what ive used over the last 15 yr keeps everthing clean.MattBLancs wrote: 06 Jan 2024, 09:22 Coolant, am thinking a full change, flush then this:
Husky.
- x 5678
I was trying that yesterday, handbook instructions useless but YouTube claims that any four digit number will work. This is for the Mazda of course. Off to daughter's today so will be trying that, also the new dashcam and a satnav I have been meaning to test for five months.MattBLancs wrote: 06 Jan 2024, 09:01 Will have another go at the Bluetooth soon, fingers crossed 0000 does the trick![]()
- x 8431
That's a mod I shall possibly do on mine at some stage... Also considering a suction device for routine changes if it can suck down far enough...MattBLancs wrote: 06 Jan 2024, 08:43Made it myself, normal sump pressed with a wooden "former" below and a fairly blunt (black, impact type) socket on the inside. Put under a hydraulic press and reshaped as shown!Huskyxantia wrote: 06 Jan 2024, 08:12You can get all the oil out this one ! Where did you get it from and do the holes line up on say 308cc or c3 picasso both 1.6hdi
I've been looking at (new) sumps again - as the 308 has the standard "inny" (like belly button) drain point at moment.
Don't have a press of my own, chatted up my friendly usual MOT garage to let me have a quick go using theirs
- x 2366
Am I right you have a press Jim?CitroJim wrote: 06 Jan 2024, 12:22 That's a mod I shall possibly do on mine at some stage... Also considering a suction device for routine changes if it can suck down far enough...
I don't think I threw away my wooden "former" - will have to dig it out
- x 8431
I do indeed Matt
Why PSA did an inverted drain plug is just beyond all understanding... What were they thinking?
- x 2366
Stocked up on both gearbox oil and coolant
Huskyxantia
- x 927
Blue prints were back to front Jim lolCitroJim wrote: 06 Jan 2024, 12:39I do indeed MattOne of the most useful tools ever...
Husky.
