Huskyxantia
x 927
Unread post by Huskyxantia »
MattBLancs wrote: 31 Dec 2023, 11:07 Is there a default code for Peugeot 308 stereo's Bluetooth connection?
(The phone suggested 0000 or 1234, will have a play later)
Will have to clear out the half a dozen previous owners phones from it too!
Doing mine last october i pinned 0000 , all works well since.
:-D
Huskyxantia
x 927
Very impressive, when changing my sump & strainer last month
There's about 500ml left in the sump because of this inward design i belive who developed this sump had the blue print back to front, now making a point of using my small battery powered vacumme pump to suck out the rest at every oil change now. Well done for modding yours
:-D
x 2366
Unread post by MattBLancs »
Huskyxantia wrote: 06 Jan 2024, 08:50 Very impressive, when changing my sump & strainer last month
Yes, I measured it too, just daft, isn't it!
The only thing that makes any sense to me is if the sump plug is recessed to reduce the risk of it being sheared off if the car was "grounded out" but if you are doing that much then the thin sheet steel of the sump itself isn't exactly armoured!
x 2366
Will have another go at the Bluetooth soon, fingers crossed 0000 does the trick [-o<
x 2366
This is a bit too much of a "it either works or it doesn't" approach for me!
I bought a second hand sump, modified it, then did a swap at next oil change. At least my method didn't have potential to leave me stranded!
I actually modified 3 sumps by this method (as had a 1.6 HDi C4 at the time too)
The third sump I used a normal socket rather than impact and the sharper edge instead punched rather cleanly through the sump instead!
As that was a spare / was going to sell it on eBay, that was the end of that!
x 2366
Strangely the undertrays when searching for 7013EC look much shorter than the Peugeot diagram Marc kindly supplied
eBay undertray
eBay undertray
But the price is much more palatable!!
x 2366
Coolant, am thinking a full change, flush then this:
eBay stuff
eBay stuff
Hexeal Red Antifreeze offers outstanding protection against corrosion, overheating and frost. Hexeal OAT is a 2 year Long Life Antifreeze with Organic Acid Technology corrosion protection. The exceptional thermlong-lifeity eliminates the risks of deposits particularly near the cylinder head, engine block, radiator, water pump and heat exchanger. Our Red Antifreeze is Nitrite, Amine, Phosphate (NAP free), Borate and Silicate free. It conforms to BS:6580 (2010), ASTM D3306, SAE J1034, ASTM D6210 , AFNOR NF R15601 (with the exception of reserve alkalinity).
Huskyxantia
x 927
Dont forget theres already part undertray there below the rad & intercooler, as for slide hammer on sump oops look at my new massive drain hole
:-D
Huskyxantia
x 927
MattBLancs wrote: 06 Jan 2024, 09:22 Coolant, am thinking a full change, flush then this:
Very much what ive used over the last 15 yr keeps everthing clean.
:-D
x 5677
MattBLancs wrote: 06 Jan 2024, 09:01 Will have another go at the Bluetooth soon, fingers crossed 0000 does the trick [-o<
I was trying that yesterday, handbook instructions useless but YouTube claims that any four digit number will work. This is for the Mazda of course. Off to daughter's today so will be trying that, also the new dashcam and a satnav I have been meaning to test for five months.
x 8427
MattBLancs wrote: 06 Jan 2024, 08:43
Huskyxantia wrote: 06 Jan 2024, 08:12
MattBLancs wrote: 01 Apr 2023, 12:47 Can you spot what is unusual about this particular DV6 sump?
You can get all the oil out this one ! Where did you get it from and do the holes line up on say 308cc or c3 picasso both 1.6hdi
Made it myself, normal sump pressed with a wooden "former" below and a fairly blunt (black, impact type) socket on the inside. Put under a hydraulic press and reshaped as shown!
I've been looking at (new) sumps again - as the 308 has the standard "inny" (like belly button) drain point at moment.
Don't have a press of my own, chatted up my friendly usual MOT garage to let me have a quick go using theirs
That's a mod I shall possibly do on mine at some stage... Also considering a suction device for routine changes if it can suck down far enough...
x 2366
CitroJim wrote: 06 Jan 2024, 12:22 That's a mod I shall possibly do on mine at some stage... Also considering a suction device for routine changes if it can suck down far enough...
Am I right you have a press Jim?
I don't think I threw away my wooden "former" - will have to dig it out :)
x 8427
MattBLancs wrote: 06 Jan 2024, 12:34
I do indeed Matt :) One of the most useful tools ever...
Why PSA did an inverted drain plug is just beyond all understanding... What were they thinking?
x 2366
Buy it now occurred
Buy it now occurred
Stocked up on both gearbox oil and coolant
Huskyxantia
x 927
CitroJim wrote: 06 Jan 2024, 12:39
Blue prints were back to front Jim lol
:-D
