x 6948
Manifold
(1) Manifold, part: 0341J2, £357.10
(2) Gasket, part: 9810697380, £27.38
Intermediate
(1) Intermediate Pipe, part: 1717LC, £580.62
Althesandie
x 5
Alarm module for 2015 grand Picasso.
Unread post by Althesandie »
Hi. Would it be possible to get the part number for the alarm module with the battery in for replacement in my car and can I possibly ask if this needs any coding? Many thanks for any info.
Vin number is WBA8L12070K861464
Reason: Topic Moved to Official Parts Thread
x 1496
Re: Alarm module for 2015 grand Picasso.
That VIN is not right - should start with a V, and even the last 8 are not recognised by PSA?
Althesandie
x 5
Huge apologies for that. Had taken a picture somewhere else on the vehicle.
Number at the windscreen is VF7**************[VIN obfuscated, can be read by forum staff]
Thanks for the quick reply!
x 6948
(5) Anti Theft Alarm Siren, part: 9677756080, £160.15 inc. VAT
In future please direct any part number requests the the specific thread here, thanks :wink: I've now moved all these posts.
Part Number Requests
Althesandie
x 5
Many Thanks
Martin3008
Unread post by Martin3008 »
Hello Team,
Would it be possible to let me know the following item part numbers (i am interested to understand the turbo banjo bolt and oil feed issues if they exists of my Peugeot and if it uses modified parts for it)
car: Peugeot 3008, year 2012, 1.6 hdi VIN: VF3**************[VIN obfuscated, can be read by forum staff]
If possible to let me know parts for:
banjo bolt for the turbo (there is a new version of the bolt)
oil feed pipe for the turbo (there is a new model which has a hose)
oil pan part number
*any service recommendations from Peugeot what to be changed or maybe i need to ask in a separate thread ?
Thank you in advanced
***i just read that i have to donate. let me try to donate today or tomorrow
Huskyxantia
x 927
Unread post by Huskyxantia »
Huskyxantia wrote: 23 Dec 2023, 09:39
Huskyxantia wrote: 15 Dec 2023, 17:36
Huskyxantia wrote: 13 Dec 2023, 14:35 Can i have part number for Oil pressure sensor switch for a c3 Picasso 2012 1.6hid. Vin VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Post here for the same vin.. part number for the oil pump and possible diagram of where it goes and so on Richard mentioned about some oil flange ? Behind the camshaft or crank , sprocket ? When blocked can throw upstream high pressure warning could you just clarify this please marc, thanks.
Same vin need part numbers for Vacuum Pump Gaskets
Many thanks Happy Christmas & all the best for 2024
Same vin is it the clutch master cylinder ? Thing that makes clutch pedal work , needing the part number , cheers marc
:-D
x 6948
(10) Declutching Master Cylinder, part: 2182C8, £120.94
x 6948
Martin3008 wrote: 04 Jan 2024, 11:59 *any service recommendations from Peugeot what to be changed or maybe i need to ask in a separate thread ?
Yes, please start a separate thread for other issues and questions, as this thread is only for official parts info. The links for donations are on the first post of this thread.
Huskyxantia
x 927
GiveMeABreak wrote: 04 Jan 2024, 17:39 Image
What about part 11.
:-D
dave101ua
Unread post by dave101ua »
Happy New Year !
Can I have the numbers of these parts please?
- FRONT SHOCK ABSORBER CUP KIT
- FRONT BRAKE DISCS
- FRONT BRAKE PADS
Oh and also the number for the part, don't know the proper name but I need to replace the small motor on the rear wheel which enables/disables break pads when hand break is used.
Thank you!
Huskyxantia
x 927
Huskyxantia wrote: 04 Jan 2024, 17:47
What about part 11.
Can i have part number for number 11 aswell please marc, thanks.
:-D
x 6948
(11) is the Clutch Slave Cylinder, part: 2182E1, £80.69
I've moved your other query to a new thread here with some other things you need to check....:
viewtopic.php?t=80729
umut
Unread post by umut »
Hello! Marc
i need to replace Fuel Return / Leak-Off Pipe, appreciate if you can let me know the part number please.
Thank you
