Berlingo Semi Auto 'Box Leaking
HORNMERCHANT
Re: Berlingo Semi Auto 'Box Leaking
Unread post by HORNMERCHANT »
My 2014 Berlingo Multispace has been leaking the actuator fluid into the clutch causing it to A - slip, B - losing the fluid so that the auto cannot select gears , i have replaced the slave cylinder/release bearing so hopefully that will cure the issue
Doo
(Donor 2022)
x 121
Unread post by Doo »
The gearbox fluid resevoir on these boxes is kinda low down at the front of the box, near the chassis leg. I had to clean a whole load of yuck off our C4 gearbox when it was off. I was delighted to see it was full & intact, but they are plastic so any rough hands in there or even a rock could potentially damage it.
Has anyone seen the plot? :?
