- x 2341
Is there a default code for Peugeot 308 stereo's Bluetooth connection?
(The phone suggested 0000 or 1234, will have a play later)
Will have to clear out the half a dozen previous owners phones from it too!
- x 8110
I'd plump for 0000 which worked on the 107 I had!!
- x 8386
I think mine told me on the display...
- x 2341
Interesting! Seemed like both phone and car were asking for a code, so perhaps we went wrong way about it? The handbook says something unhelpful like "enter a four digit code" but makes no mention of defaults etc.
Will have a play when we are back home again
- x 2341
308's gearknob is quite worn, so less than £5 should sort this.
Has car mats in the back but none in front door well, have gone for grey to brighten it up a touch. Slightly posher than the "cheapest possible" choices (about £18 is as cheap as they go) so hoping are good.
Engine bay undertray missing so researching this at present.
- x 2341
308 SW:
Had a quick look at front left wheel - as it clearly has a puncture (down to about 1 bar on the gauge) no obvious nails or damage to the tyre. The tyre itself is about two thirds worn and a presumably cheap "Winrun"
Lacquer is still present or was, but sat over a variable thickness of white aluminium oxide for a large area of the diamond cut faces.
The anthracite coloured paint is also lifting in many areas, strangely lots on the back too. This chipper off and some white paint brushed on for the moment. (Wow that's blurred!)
Currently exploring a set of wheels, down a size to 16" most likely, then can take the others off and sand down and repaint them at my leisure.
These: Or Seem good options.
Wheel bolts were very tight and bone dry. Thin smear of copper grease and done to 95 Nm. No locking nonsense thankfully!
(Online research now suggests this maybe should be 100 Nm)
- x 8386
Must have been the paint fumes Matt!
Onlinemyglaren
- x 5674
I get that with my phone, sometimes it doesn't know how to focus,
- x 2341
I think it was likely a long shutter speed as was pretty gloomy.
- x 2341
Put a few queries on the parts thread (viewtopic.php?p=785714#p785714 ), copied here to add extra detail without waffling too much in that thread
Hi, few queries on the 308 SW 1.6 HDi, six speed manual.
VIN
VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Can you please confirm part number for the following:
- Engine bay undertray (aftermarket seems to be two types a long one and a short one!)
Missing as seems to be the norm. Aftermarket ones surprisingly cheap (£45 or so, delivered) think worth adding. Likely do my own fixings, M6 bolts and penny washers.
- oil filter (Autodoc putting the wind up me with two different types looking at the pictures!)
Some look as I recognise from the 206's DV6 (16v) but wanted to be sure the later 8v is the same.
- coolant: should I be looking for an OAT type (or one without porridge?)
Bit murky looking, will give it a flush and refresh.
- alternator: part number and / or confirm if this is clutch pulley type?
Will dig into this more, I think it's a standard pulley on there now, has a "dancing tensioner" which I think is symptom of a solid pulley.
- gearbox oil type / part number? (I'm assuming 75W80 API GL4 but thought best to check) actually quantity too would also be helpful.
Always think this is worth changing. Not planning on output seal change at present (will check no signs if leakage before swapping the oil)
VIN
- x 2341
Fantastic turn around on answers to all the above from Marc, viewtopic.php?p=785726#p785726
Also pasted here for ease of reference:
Feel a bit lazy considering I've just been asleep whilst all that was completed!!
Similarly super quick response on the stickers (as just renewed my membership here) by Jim tooGiveMeABreak wrote: 06 Jan 2024, 01:43
(1) Soundproofing under engine and gearbox, part: 7013EC, £381.91
(8) Oil Filter
OEM part: 1109AY, £18.54
Cheaper Alternative, part: 1687120580, £9.40
Coolant
PSA use Freecor
Part: 1637756380: Freecor DSC Fluid (Ready for use), 2 litre container, £11.06
Part: 1637756080: Freecor DSC Anti Freeze 1 Litre Container, £9.31
Alternator
This is a 'Reversible Alternator' type.
New 180 Amp Valeo (IST60C028) or (IST60C017) OEM, part: 5705PA, £1720.15
Valeo Exchange (IST60C028) or (IST60C017), part: 1625944380, £871.70
Gearbox Oil
Total Transmission BV SAE 75W80 (Before the 01/01/2012 or up to the RPO number 12836)
Your RPO is 12748, so this is the recommended oil.
Huskyxantia
- x 906
You can get all the oil out this one ! Where did you get it from and do the holes line up on say 308cc or c3 picasso both 1.6hdiMattBLancs wrote: 01 Apr 2023, 12:47 206's turn for a bit of TLC
Oil change, C2 spec 5w30 fully synthetic from GSF, Bosch oil filter "from stock"
Short change interval since last one slightly as thought would do it good and mostly as dropped the oil out last time on a Sunday afternoon and then discovered none of the four bottles of oil I've gathered were the correct C2 spec. So it's had a little go with some Mannol 5w30 fully synthetic cheap stuff (20 litre drum, worked out about £6 per oil change!) But concerned as not "low SAPS"
Can you spot what is unusual about this particular DV6 sump?
Husky.
Huskyxantia
- x 906
a bit like me....
Husky.
Huskyxantia
- x 906
Ive been using the same oil Matt, if you do shorter oil changes its fine.
Husky.
- x 2341
Made it myself, normal sump pressed with a wooden "former" below and a fairly blunt (black, impact type) socket on the inside. Put under a hydraulic press and reshaped as shown!Huskyxantia wrote: 06 Jan 2024, 08:12You can get all the oil out this one ! Where did you get it from and do the holes line up on say 308cc or c3 picasso both 1.6hdi
I've been looking at (new) sumps again - as the 308 has the standard "inny" (like belly button) drain point at moment.
Don't have a press of my own, chatted up my friendly usual MOT garage to let me have a quick go using theirs
